Thread started 13 Feb 2009 (Friday) 19:56
Best wide angle zoom for 5DII?
kevinma
Joined Oct 2004
Feb 13, 2009 19:56 |  #1
I have the Canon 10-22 EFS which I use on my 40D but I am going to buy a 5DII. Which lens should I buy to replace the 10-22 on the 5DII? I have the 24-105L. Thanks in advance...
x.pozhr
Gallery: 323 photos
Feb 13, 2009 20:02 |  #2
I replaced my 10-22 with a 17-40L. Haven't had much time to shoot with it, though.
So the jury is still out.
Gear List + Marketplace Feedback
BigBlueDodge
Feb 13, 2009 20:10 |  #3
I would hold off buying a WA for the 5D until you get a chance to use your 24-105L. When I was shooting 1.6x, I had a 10-22 and 17-55. When I went FF, I found that my 24-70L was plent wide enough. If you regularly shoot wider than 15mm on your 10-22, then I would recommend that 17-40L as a great, midrange WA for your 5D MKII
David (aka BigBlueDodge)
Gear
DL.Photography
Feb 13, 2009 20:18 |  #4
Alot would probably reccomend the 16-35 f/2.8L II. But if you don't need such a fast UWA, the 17-40 is pretty good.
- Dan
Gear List & Feedback
4g63photo
Feb 13, 2009 20:20 |  #5
I agree with big blue. Im in the same boat. 24mm is pretty wide on FF.
-Fernando-
sunnygirl
Feb 13, 2009 20:21 |  #6
pratman64 wrote in post #7320973 (external link)
I did the same thing and have been very happy with the 17-40L and way cheaper than the 16-35L, if dollars are an issue, as I don't need the 2.8
Susan
5D MKII - Accumulating way too much gear - bring on retirement so I have time to use it.......
kevinma
Joined Oct 2004
Feb 13, 2009 20:22 |  #7
BigBlueDodge wrote in post #7321010 (external link)
Good point...
BigBlueDodge
Feb 13, 2009 20:26 |  #8
I always advocate buying the wider aperture version of a lens when you have a choice. But WA is one area where that rules breaks down. I'm not concerned by speed (f/2.8 or f/4.0) in a WA lens, because I am generally using a tripod, or the 1/focal length rule gives me some pretty easy shutter speeds to hit without introducing camera shake. With the 17-40L, I should be shooting at roughly 1/20 sec or faster to prevent camera shake in the images. With the high iso capabilities of the 5D MKII, getting 1/20 sec shutter speeds should NOT be hard to do. Therefore I see little benefit to buying the 16-35 over the 17-40L
Gear
4rgentum
Feb 13, 2009 21:28 |  #9
i JUST picked up a 16-35 for my 5d2 today. Rented one a couple weeks ago and fell in love with it.
5DII //30D
canon 15mm Fisheye //16-35L //50 1.4 //85 1.8 //200 2.8L
3 EF-500 DG Supers //2 AB800s
dpulez
Joined Oct 2004
Feb 19, 2009 13:10 |  #10
The 16-35 mkI is only very slightly softer in the corners than the mkII, and its a lot cheaper, lighter, smaller filter, I would suggest it instead of the 17-40.
dpulez
Joined Oct 2004
Feb 19, 2009 13:11 |  #11
Then again- due to the nature of wide angle lenses, some for sale will have an issue, I'd advise to try before you buy.
amoergosum
Feb 19, 2009 13:42 |  #12
16-35L MKII
1,513 views & 0 likes for this thread
Latest registered member is MarcusBullen
828 guests, 192 members online
