Thread started 14 Feb 2009 (Saturday) 08:49
How I photograph receptions
tim
Light Bringer
Post edited over 6 years ago by tim. (29 edits in all)
Feb 14, 2009 08:49 |  #1
Wedding receptions are often very, very dark places, i've seen receptions with ambient light levels that need ISO3200/F2.8/0.5sec to expose correctly! Even with a modern camera and fast primes with ISO6400 and F1.4 you'd need 1/16th, which personally I find too slow because of camera shake and subject movement. The quality of light isn't always very flattering, with a mix of candles, tungsten bulbs, and fluorescent lights. Because of that I choose to light most receptions, overpowering the ambient light, though sometimes I set up to enhance it using gels and lower powers. Beware that a cto gel to match tungsten can lose a stop of power. If you want to take an ambient shot to show the atmosphere it's easy to flick back to Av mode and ramp up the ISO to try to get a decent shot.
I typically use two Canon Speedlites (external link) (550/580) on these stands (external link), with Canon CP-E4 battery packs (external link) to cut recycle time by 2/3. The lights are triggered by Skyports (external link), with locking PC cords from www.flashzebra.com (external link) so I can have a flash on the hotshoe as well. I use this cord (external link) to connect the skyports to the flashes, and this bracket (external link) to connect the flash to the stands. I used to use Sunpak flashes, but they didn't recharge quickly enough for me, and with a home made battery pack one of them almost caught fire at a reception, so I switched to all Canon for performance and reliability.
If the venue has white ceilings I usually use between 1/4 and 1/2 power on the flashes, which gets me ISO400-800, F2.8 - F4.5, depending on the venue. If the ceilings aren't white I point the flashes directly at the head table, usually at around 1/16th or 1/32nd power, which gives me ISO400 F5.6 or so.
As a quick aside - for location lighting I use a Morris Soft Box (external link) which is about 20", with the speedlite, battery pack, and skyport mentioned above. My assistant holds it, it's quite light.
Here's a few examples.
#1 - this shows the setup
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/rec1.jpg
#2 - this shows the type of lighting I get with the setup above
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/rec2.jpg
#3 - a cake cutting setup
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/rec3.jpg
#4 - a whole room shot, to show what two strobes can do. I probably used a little bit of on camera flash too.
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/rec4.jpg
#5 - this room had a black ceiling and green walls. I photographed the head table using direct off camera flash. ISO400, F5.6, 1/125th, flash power probably 1/16th or so. I used 70mm so each person was about the same size but still keep some DOF, at 17mm the guy in front would be huge and the girls at the back tiny. Beware harsh shadows if you shoot direct, like the silhouette of the person on the front of the head table's tablecloth.
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/rec5.jpg
People have asked for photos of how I set my camera up, so here they are
Camera with custom locking PC sync cable fromFlashZebra.com (external link)
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/ocl1.jpg
Showing the connection to my camera
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/ocl2.jpg
It's mounted to the flash head with velcro on the flash head and the transmitter. Ideally I mount it with the antenna away from the transmitter body, pointing up
IMAGE: https://www.mrwild.co.nz/hotlink-ok/potn/ocl4.jpg
timecut
Feb 14, 2009 09:49 |  #2
tim wrote in post #7323354 (external link)
On camera speedlite fill, skyports triggering speedlites fed by CP-E4's. Flash on camera not always turned on. Speedlites on stands between 1/4 and 1/2 depending how I feel on the day. Lights on stands pointing at ceiling if it's white, otherwise pointing directly at the head table on 1/32nd or so. I usually get ISO400 F4, more or less.
pretty cool image!!
Timecut Photography - http://www.timecut.comexternal link
Facebookexternal link
rammy
Joined Oct 2004
Feb 14, 2009 09:49 |  #3
Thanks for the example Tim. Looks nice and bright.
How do you trigger the Skyports if you have a flash on your camera hotshoe? Where do you have the Skyport trigger connected to fire the remote flashes? Do you use the 2.5mm sync port on the transmitter?
Gear | Surrey Wedding Photographer (external link) | Surrey Wedding Photographer Blog (external link) | London Architecture Photographer (external link)
form
"inadequately equipped"
Feb 14, 2009 10:23 |  #4
If I were doing the same thing I would hide a low bare flash behind the table too if there's room, and set it at low power, just to give an edge light.
Most places I've been to don't have such conveniently low, white ceilings.
Las Vegas Wedding Photographer: http://www.joeyallenph​oto.com (external link)
Peacefield
Feb 14, 2009 14:31 |  #5
I'm glad you posted this because I've heard of a few people saying the don't use on camera flash for receptions at all, just a few strobes perpetually pointed at the ceiling. My question, though, is how do you adapt to the ongoing event? The dancing, people at the tables, etc. Do you move them around all night? Do you use them just for head table shots?
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
form
Feb 14, 2009 14:39 |  #6
Probably moves the stands. I would (and do) if needed. I use anywhere from 3-5 off camera flashes now for wedding receptions. I almost always want a kicker edge/rim light and a good fill light somewhere, especially for the dance floor.
photagraph
Feb 14, 2009 18:47 as a reply to  @ form's post |  #7
I want to try something like this! Not sure it'll work that well with canons wireless triggering though.
tim
Light Bringer
Feb 14, 2009 21:04 |  #8
rammy wrote in post #7323612 (external link)
I have a speedlite on the hotshoe, and the skyport transmitter is velcro'd to the flash head and connected to the camera's sync port. Yep I use the little sync port on the transmitter.
form wrote in post #7323799 (external link)
I'd say about 1/2 of the reception halls I photograph in have white ceilings. For the ones that don't I shoot the flashes direct at much lower power.
I could have hidden the stands, or I could photoshop out the light stands, but I don't see a big need.
Peacefield wrote in post #7324973 (external link)
I move the lights whenever I need to. As they are they light the front half of the hall fine. I have the on camera speedlite if I need to light other places.
photagraph wrote in post #7326121 (external link)
Nope, it'll be unreliable. You need skyports (external link), pocket wizards, or the alien bee ones.
RobNYC
Feb 15, 2009 13:33 |  #9
Thanks for posting this Tim!
Rob
1d mk III; 5D mk II; EF 24-70 f/2.8L; EF 70-200 f/2.8L IS; 50mm f/1.4; 580 EX II; Vivitar 285s; Pocket Wizards; Other lighting gizmos
www.robcorbettphotogra​phy.com (external link)
http://robcorbett.zenf​olio.com (external link)
stathunter
"I am no one really"
Feb 15, 2009 13:37 |  #10
That looks like a perfect location for off camera lighting. Lately the locations I have had are not so perfect.
Scott
"Do or do not, there is no try"
bnlearle
Feb 15, 2009 13:38 |  #11
Radiopoppers are a great option for those of us in civilized nations :p
twitter (external link) // facebook (external link)
Website (external link)
San Diego Wedding Photographer blog (external link)
lil_miss
Feb 15, 2009 14:09 |  #12
They're coming to NZ very soon!! :) Eagerly awaiting
A bunch of Canon bits and pieces.
Blog (external link) :: Facebook (external link)
tim
Light Bringer
Feb 15, 2009 15:55 |  #13
I have no desire for radio poppers. In this situation having a consistent amount of light means all my shots come out the same brightness, and need exactly the same post processing. Using ETTL they're all going to come out different and would need to be processed individually, by hand. That slows my workflow down a LOT.
Also using ETTL you do occasionally get some weird results. In long grass the other weekend I had 95% good exposures, but 5% were two stops overexposed with the same framing. I have no idea why.
I use manual flash more than I use ETTL now, I just like the consistency. Of course I have an assistant manning the flash when we're doing an interactive session, by myself it'd probably be too time consuming.
Matt30D
Feb 16, 2009 10:23 |  #14
Tim- I have a 580EX and 4 430's, what could you do with this set up..with all 430's on stands? Be CREATIVE>
www.schuldtimagery.com (external link)
Gear: 5D/5DII/30D
Lens: 28-75, 85 1.8, 70-200 2.8 IS, 50 1.8, 17-40L
form
Feb 16, 2009 10:43 |  #15
Assuming you're using the built-in infrared, I would put them really close to you at all times and pray the triggering system works.
Creatively I might try a triangle or square pattern and point them from the corners/edges into the middle of the room, all raised and pointing downward, all with umbrellas/brollies. The 580EX would then fill wherever needed.
91,485 views & 0 likes for this thread, 63 members have posted to it and it is followed by 8 members.
Latest registered member is groundzero112
721 guests, 224 members online
