Thread started 14 Feb 2009 (Saturday) 16:09
Photographing Fine Art – Questions
puggle
Feb 14, 2009 16:09 |  #1
I'm photographing a painting and need some help!
I have two entry level studio strobes (100 watt seconds each) and set them up with (2) 40 inch umbrellas, facing backwards, to spread the light for a larger light source.
The painting is approx 30"wide x 42" tall.
I'm using a 24-105 zoom, shooting in manual mode at f11. (canon 5D).
I get good, sharp exposures, but am having difficulty with balancing the light evenly across the painting.
Another problem is, I can't seem to get it squared-up!
It's skewed. I tried moving the camera and ckecking the paralax in the viewfinder, and it looks pretty close, but I can't get it perfect.
Only solution so far is to distort it back to normal in Photoshop. Seems to work well, but it's not perfect.
Anyone?
Puggle
Canon 1DXmkII, 5DmkIV, Sony A7rII, PhaseOne XF IQ100, PhaseOne 645DF+D
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Feb 14, 2009 21:13 |  #2
It's skewed.
Use a long lens & get away from it. Farther is better.
studio strobes
Set at a 45-degree angle from the art? You might try then without the umbrella. A point source should give fewer highlights from an oil painting.
Photographing my Artwork
How to Photograph Art (external link)
artyman
Sleepless in Hampshire
Gallery: 17 photos
Feb 16, 2009 16:58 |  #3
If it is an oil painting you are probably going to get reflections from the surface owing to the reflective nature of oils and the varnish. I would suggest using a polarizing filter. Watercolours are not such a problem, but remove it from behind the glass first. As regards getting it squared, make sure the centre of the lens is pointing at the centre of the painting, measure it, then measure from the lens centre point to the four corners of the painting, that figures should be the same.
Ken
896 views & 0 likes for this thread, 3 members have posted to it.
1029 guests, 112 members online
