I am looking into getting a fisheye but I wanted to make sure it would work with my XSI before I purchase. I have heard something about needing a full frame mirror or something like that to be able to get 180 degrees.
dle42 Member 153 posts Joined Jan 2008 Location: California More info | Feb 14, 2009 20:51 | #2 It will work on your XSi, but because of the crop sensor of the camera, you won't get as pronounced of a fisheye effect.
GetOnMyLevel Senior Member 538 posts Joined Jun 2008 Location: LA More info | Feb 14, 2009 20:51 | #3 it would work. you wont get much fish effect though.
Jman13 Cream of the Crop 5,567 posts Likes: 164 Joined Dec 2005 Location: Columbus, OH More info | Feb 14, 2009 20:53 | #4 Don't forget the Tokina 10-17....also made for crop cameras, with the flexibility of a zoom (and very good image quality). Great lens. Works on 1.3x cameras at 12.5mm and beyond, and on full frame at 15mm and beyond too, so it's very versatile. Jordan Steele - http://www.jsteelephotos.com
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Feb 14, 2009 21:47 | #6 The Sigma 10mm fisheye is designed for the XSi and will give you almost 180 degrees. The 15mm fisheye is not very wide, an UWA lens like the 10-22 is wider on an XSi. GEAR LIST
_aravena isn't this answer a stickie yet? 12,458 posts Likes: 12 Joined Feb 2007 Location: Back in the 757 More info | Feb 14, 2009 23:33 | #7 Roughly the difference. I wish I still had my Tokina 10-17 FE. Awesome lens, I would post a more equal example. 17mm Last Shot Photography
JustChillin Senior Member 301 posts Joined Feb 2009 Location: Southern California, USA More info | Feb 15, 2009 06:20 | #8 yes it will work on an xsi. 5D mkII l XTi l 1D mkIIn l 15mm f2.8 l 16-35 f2.8 II l 24-70 f2.8 L l 35 f2 l 50 f1.4 l 85 f1.8 l 70-200 f2.8 IS l 400 f5.6 l Kenko 1.4x 300 Pro l Canon 2x mk I l 580 EX II l 500 DG Super l Kenko ext. tubes l 50 f1.8 mk I l 18-55 kit lens l Previous Gear
Jman13 Cream of the Crop 5,567 posts Likes: 164 Joined Dec 2005 Location: Columbus, OH More info | Feb 15, 2009 06:56 | #9 That's the beauty of the 10-17...you can get that crazy, near 180 degree FOV at 10mm...and temper the distortion and get a near rectilinear UWA at 17mm. (17mm fisheye is roughly as wide as 12mm rectilinear...10mm fisheye is WAY wider than 10mm rectilinear.) On my 1DII, I get a full 180 degree shot at 12.5mm, and still get to temper the width a bit to 17mm. Jordan Steele - http://www.jsteelephotos.com
MPCman Senior Member 863 posts Likes: 30 Joined May 2008 Location: Amsterdam, the Netherlands More info | Feb 15, 2009 07:35 | #10 Flyguytki wrote in post #7326706 I am looking into getting a fisheye but I wanted to make sure it would work with my XSI before I purchase. I have heard something about needing a full frame mirror or something like that to be able to get 180 degrees. Just to make sure you understand what's going on: 7D, EOS-M, 100-400 L, 15-85, Tokina 11-16 2.8, EF-M 11-22, 55-200
| Latest registered member is Mihai Bucur 1154 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
