How much does Canon charge for lens calibration if you don`t have a warranty anymore?
Kris_2020 Senior Member 516 posts Likes: 38 Joined Oct 2007 Location: Canada, Ontario More info | Feb 15, 2009 20:13 | #1 How much does Canon charge for lens calibration if you don`t have a warranty anymore? Canon 5D IV | Canon 70-200mm f/2.8 IS L Mark 2 | Canon 85mm f/1.8 | 580 EX II
smorter Goldmember 4,506 posts Likes: 19 Joined Nov 2007 Location: Melbourne, Australia More info | Feb 15, 2009 20:14 | #2 Depends on the region, in Australia it's about $150 AUD, and sometimes they even replace parts like damaged circuit boards as part of the cost Wedding Photography Melbourne
Kris_2020 THREAD STARTER Senior Member 516 posts Likes: 38 Joined Oct 2007 Location: Canada, Ontario More info | Feb 15, 2009 20:40 | #3 smorter wrote in post #7332518 Depends on the region, in Australia it's about $150 AUD, and sometimes they even replace parts like damaged circuit boards as part of the cost My experience is that getting a lens calibrated is often useless, you need to get your lens and camera calibrated together. Canon usually give a discount in this regard. (but you can try to get it calibrated individually first to see if that alleviates the problems to save costs) You also get a warranty on the work, so you can get a free re-calibration for whatever the rework period is (in Australia, 6 months) Is AF microadjust not working for you? It is hard to pinpoint what I need to set the Micro Adjustment to. Canon 5D IV | Canon 70-200mm f/2.8 IS L Mark 2 | Canon 85mm f/1.8 | 580 EX II
smorter Goldmember 4,506 posts Likes: 19 Joined Nov 2007 Location: Melbourne, Australia More info | Feb 15, 2009 21:55 | #4 What I suggest is setting up a large flat target (e.g. a rigid box with contrasty text on it (e.g. Canon Lens Box - though this may be too small) that more than encompasses the AF point (the bigger the coverage the better)) and set it up parallel to the front of the lens at least 10X focal length away from the camera. Then take a series of shots using standard procedures (i.e. on Manual, Tripod, self timer etc.) at -10, -5, 0 and +5 and +10 at about 3 shots each, manually defocusing, and then AFing again. inspect which of them are on average sharpest, then narrow your test to that range. Wedding Photography Melbourne
bohdank Cream of the Crop 14,060 posts Likes: 6 Joined Jan 2008 Location: Montreal, Canada More info | Feb 15, 2009 22:09 | #5 Which lens are you talking about. If a zoom, it's not uncommon that the lens is off different amounts at different focal lengths and sometimes at different distances. You lock it in at one focal length one distance and it throws it off at other distances and focal lengths. Depends what's wrong with the lens to start with. Bohdan - I may be, and probably am, completely wrong.
sun5150 Member 161 posts Likes: 2 Joined Jan 2007 More info | Feb 15, 2009 22:22 | #6 I just had a 70-200 2.8 done by Canon Irvine.
Kris_2020 THREAD STARTER Senior Member 516 posts Likes: 38 Joined Oct 2007 Location: Canada, Ontario More info | Feb 15, 2009 22:42 | #7 Well it seems like all my lenses are off a bit. I`d say +5 but the one that bothers me the most is the 100-400. Canon 5D IV | Canon 70-200mm f/2.8 IS L Mark 2 | Canon 85mm f/1.8 | 580 EX II
goose2 Member 215 posts Joined Dec 2008 More info | Feb 15, 2009 23:37 | #8 Some will disagree with my method but I screwed around with mine all day. Here is what I did to get mine fined tuned. I took pictures of fake flowers in a vase with the flowers at different distances away. They were only 2" apart, so not a great amount. I then focused on the flower that was in the center away and took the shots. All of it was done at the smallest appeture # off of a try pod. My first shot was focusing on the front flower and + 5 setting was real close to where I wanted to be but I ended up with +4 being the best.
PapaCarlo Senior Member 587 posts Joined Jun 2008 More info | Feb 16, 2009 02:59 | #9 Permanent bansun5150 wrote in post #7333434 I just had a 70-200 2.8 done by Canon Irvine. $177.48 total. Comes with 6 months warranty. Pictures look the same to me. I don't think they did fix. Will try it for a month and see. I've sent mine three times there and it always would come back the same. I had to go via legal channels and they asked me to send the gear one last time. I agreed on condidtion that I would not send them to Irvine and sent it to New Jersey instead. That did work and finally I can take some pictures
jtfoto Member 83 posts Joined Nov 2003 Location: Wagga Wagga - Australia More info | I had my 70-200 2.8L calibrated by Canon Australia abouth the middle of last year and I was charged $99.00. EOS5D Plus Grip,2 X EOS 5D11's plus grips, EOS 1VHS, 1DS Mark 2.
sun5150 Member 161 posts Likes: 2 Joined Jan 2007 More info | I'm sending mine back tomorrow.
Feb 16, 2009 23:31 | #12 I just sent my sigma 10-20mm lens in to get serviced. It ran me $95 plus $10 for shipping.. Still waiting to get it back so I'm not sure what the results will be. Kevin: 5D Mark III, Canon 7D
| Latest registered member is SteveeY 1757 guests, 176 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
