Thread started 20 Feb 2009 (Friday) 08:17
PWs, sekonic 358 and 580ex II
jenirose3
Feb 20, 2009 08:17 |  #1
I love my ABs. But I've decided to give the speedlight a go since hauling the bees around is rough. I have the 580exII, the PW Plus II and a sekonic 358 w/ RT. I need some expert help.
The RT on the sekonic...if I take a light reading and set it will it trigger my PW and 580exII at that setting? what does the 580exII need to set at?
I feel so lost.
I need some help!
Jeni
Canon 5D|20D|L Glass|Primes|ABs|580ex​II|pocketwizards
Looking for: Canon 70-200mm f/2.8L IS USM
http://www.lolaandme.c​om (external link), http://www.provocateur​photography.com (external link), http://www.modelmayhem​.com/provocateurphotog​raphy (external link)
PacAce
Joined Feb 2003
Feb 20, 2009 08:39 |  #2
jenirose3 wrote in post #7366559 (external link)
I feel so lost.
I need some help!
Metering the 580EX in manual mode should be no different than metering your AB strobes. The setup should be the same in both cases. All you're doing is replacing an AB strobe with the 580EX in the setup.
...Leo
silvex
Gallery: 21 photos
Feb 20, 2009 16:32 |  #3
YOu can also chimp...:) I would start with 1/2 power on the speedlite. Using it at full blast 20 times in a row. The unit will shutoff for 20 minutes I *think*. Keep also in mind that using modifier (umbrella, softbox). Yo will lose a 1-2 stop of lights. So adjust the ISO. I have do ISO400+ with speedlites and umbrellas with 50mm lens on 40D for 1/2 body shots.
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
1,006 views & 0 likes for this thread, 3 members have posted to it.
1587 guests, 137 members online
