Thread started 21 Feb 2009 (Saturday) 04:54
A crack @ M31 processing (image not mine)
dpastern
Feb 21, 2009 04:54 |  #1
Image data from:
http://www.mistisoftwa​re.com/astronomy/index​_fits.htm (external link)
In accordance with image usage rules:
Image Acquisition by Jim Misti and Steve Mazlin
I've done the processing using Photoshop CS2 and FITS Liberator, using the tutorials here (brilliant tutorials imho):
http://rdelsol.com/Pre​sentations.html (external link)
In lieu of having clear skies to actually use my own scope/DSLR setup, I've taken to learning how to process astro images using other peoples. Since the owners of these data files are kind enough to 1) allow others to use, i.e. play around with them, and 2) post the resultant PP shots on websites etc, I'm hard @ work learning :-) This image has taken me a few hours of carefully following the tutorials etc. I've had a *lot* of fun doing this. I'm sure the image could be made better, this is really my first attempt!
Without further ado (large image download, may take some time to display):
I'd really like to thank both Jim Misti and Steve Mazlin for their kindness in offering these images to play with.
Cheers,
Dave
chris.bailey
Joined Jul 2003
Feb 21, 2009 10:56 |  #2
I have played with the same data in the past and very good it is. Your process has blown out the core and clipped the black, the formeer being the major trick to imaging and processing M31.
dpastern
Feb 21, 2009 12:03 |  #3
Yeah, I realised that I blew the core - hence the practicing :-)
Dave
dpastern
Feb 22, 2009 04:21 |  #4
I'm not sure what you meant by clipping the black (or how you could tell so, unless you mean the histogram creeping up the black end?). Here's a 2nd attempt:
Dave
policy
Feb 22, 2009 07:27 |  #5
Wow! What a difference!
Canon Digital Rebel T5i, EF-S 17-85mm IS, EF-S 18-135mm IS STM, EF-S 40mm f2.8, EF 50mm f1.8, Speedlite 430EX + some stuff
chris.bailey
Joined Jul 2003
Feb 22, 2009 08:35 |  #6
Second is much much better and closer to what I got with the same data, core is still a little blown. Clipping the black is pretty obvious as empty space is not jet black. If you consider where that the in astrophotography all of the data is squeezed into a very narrow portion of the histogram, by clipping the backkground to black, you are loosing some of those photons you have worked so hard to get a hold of. If you avoid clipping the black with this data you will find that the faint outer reaches of M31 almost stretch from corner to corner.
Nighthound
Gallery: 224 photos
Best ofs: 24
Feb 22, 2009 09:48 as a reply to  @ chris.bailey's post |  #7
You're making progress Dave and that's the goal. You did well.
To better demonstrate black point clipping I attached your image histogram and one from one of my attempts. I don't know how much total data was collected in your image so I realize I'm not comparing apples to apples in these two images but it does help demonstrate what "clipping" is and looks like.
As you can see all channels are pushed all the way left on your histogram graph. The red and blue channels being the most clipped. Try to aim for a histogram the peaks away from the left side as well as one that has all three channels peaking at the same area on the graph, this will insure better color balance. It's a good idea to keep the multi-channel histogram in view during the entire process to help keep an eye on color balance and clipping.
IMAGE: http://i3.photobucket.com/albums/y67/Nighthd/Astrophotography/test/tst2/clip.jpg
IMAGE: http://i3.photobucket.com/albums/y67/Nighthd/Astrophotography/test/tst2/noclipx.jpg
Hope this helps some.
Steve
chris.bailey
Joined Jul 2003
Feb 22, 2009 13:16 |  #8
A quick play with that data gets. Core is still alittle hot (but then it is in the L channel of the data) and its a little green and has a bit of a gradient to it but you get the idea.
I have found the histogram in PS a bit insenstive for astro images and prefer the precision of PixInsight
dpastern
Feb 22, 2009 14:11 |  #9
Ah good, the black clipping was what I thought you meant. I'll probably have another go at this during either this week, or probably the weekend where I have more time @ hand.
Chris - I did have the galaxy dust lanes that far extended at one stage during my processing, but added some contrast which ended up removing some of the dust on the outer edges.
Thanks Steve for the clipping visuals - excellent, I have some idea what I'm doing! And need to do.
A question - how did you both manage to present the core like that? It looks far nicer and more natural than my 2nd attempt, more gradual.
Thanks for the input, much appreciated.
Cheers,
Dave
dpastern
Feb 22, 2009 14:13 |  #10
Oh, and Steve, that's the 2nd M31 shot I've seen with a lot of Blue nebulosity in it. I don't seem to be able to pull that out of the data, anything I'm missing?
Dave
MidnightSun
Feb 27, 2009 16:52 as a reply to  @ dpastern's post |  #11
Nice progress and info. Processing is what I'm trying to get a handle on now. Just reading everything I can find and alot of practice......
Dave
Canon 350D, AE-1, Orion 8" Newt. f/4.9; EQ6 w/ modified motor drive; Orion 70mm f/10 Refractor Guide Scope; Celestron NexImage CCD Imager; Starshoot Autoguider. Orion Electronic Focusers.
Astro Setup / Midnight Sun Astrophotography (external link)
dpastern
Feb 27, 2009 17:47 |  #12
MidnightSun wrote in post #7420974 (external link)
That's what I'm doing Dave!
Dave
9,342 views & 0 likes for this thread, 5 members have posted to it.
1064 guests, 104 members online
