Thread started 21 Feb 2009 (Saturday) 12:44
Bracketing using G9
ione
Feb 21, 2009 12:44 |  #1
I hope somebody here could enlighten me how to shoot using this feature.
I just can't get it to work. I think I might be missing a step or two.
I go to the Function button and activate BF
Click Display button to make selection of range of different aperture settings
Select continuous shooting from Function wheel
However, I can't see it to make it work, in fact I keep the shutter button down and it doesn't shoot multiple shots like it suppose to.
I also read on the manual that I would need a faster card,
I am able to use this feature on my 40D w/o any problem so what am I missing?
omaruk
Feb 21, 2009 15:16 |  #2
You need to turn the flash off and not be in auto mode
Jakpro
Feb 21, 2009 18:25 as a reply to  @ omaruk's post |  #3
Have you tried it without setting continuous shooting?
Try using P, Av, Tv, then selecting AEB, then the turn on the AEB and then the exposure setting. (p. 131 in the manual)
denncald
Feb 21, 2009 19:24 as a reply to  @ Jakpro's post |  #4
As Jakpro said, read page 131, and only press the shutter button once, it is not the same as continuous shooting option. The camera will take multiple exposure shots on it's own, after your single shutter activation.
Dennis
DaryleH
Feb 21, 2009 23:13 |  #5
denncald wrote in post #7376877 (external link)
Dennis
It's kind of like pouring pee out of a boot, the directions
are on the heal.;)
ione
Feb 22, 2009 13:37 as a reply to  @ DaryleH's post |  #6
Yes that is how I shot the first time
I have used M, T.
But do you agree with the sequence of steps I took, ie.,
selecting the mode
activating aeb
click display select range of subsequent shots
you need to turn the flash off and not be in auto mode
I always have it off
I read it and I didn't interpreted as pressing the shutter once, but I will now. So what you are telling me that if I press the shutter once the camera will shoot the other remaining 2 shots?
Can you explain me the difference between pg 126 and 131. I think 126 applies for M mode and therefore I have to select MF right?
GordonSBuck
Joined Jan 2003
Feb 22, 2009 13:44 |  #7
Seems that it should work for you. However, just in case some settings have been missed, unlike your 40D, the G9 auto exposure bracketing does not work in manual exposure mode.
Gordon
http://lightdescriptio​n.blogspot.com (external link)
My 10 Best Photos: http://hornerbuck.smug​mug.com …187_MdCXA#56343​6691_UdXpt (external link)
ione
Feb 22, 2009 14:20 |  #8
Please look at pg127 it has listed P TC AV M shooting modes for bracketing
Jakpro
Feb 22, 2009 15:37 as a reply to  @ ione's post |  #9
P. 127 is focus bracketing
You want exposure bracketing in page 131
denncald
Feb 22, 2009 15:46 as a reply to  @ Jakpro's post |  #10
Also, if you try focus bracketing, you only press the shutter release once.
Dennis
Jakpro
Feb 22, 2009 16:17 as a reply to  @ denncald's post |  #11
One possibility that came to mind would be the slim chance that your camera is not working correctly. If you have followed the instructions to the letter and it does not work, I would guess that the only recourse would be to send it in for repair.
All I know is that mine works fine for bracketing when following the instructions.:lol:
BeyondTheNorm
Gallery: 59 photos
Sep 19, 2010 14:10 as a reply to  @ Jakpro's post |  #12
try these settings:
Manual Mode
<Function> Bracketing> Focus Bracketing (ON)
<Display> then wheel to adjust Focus range
Flash OFF
Manual Focus, then wheel to adjust initial focus point
If the FB icon is gray in the sidebar view that means it is not ready because one of the above settings is not selected
compose image and then HOLD shutter, it will take 3 frames.
Good luck!
BeyondTheNormPhoto (external link)
Zenit 35mm film, Fuji GAZ645, Fuji XT1, Fuji XT3, 10-24mm, 35mm, 50mm, 18-55, 50-200, various OCF units
6,689 views & 0 likes for this thread, 7 members have posted to it.
Bracketing using G9
1242 guests, 122 members online
