Thread started 23 Feb 2009 (Monday) 11:20
DxO for lens/optical corrections only?
PixelMagic
Feb 23, 2009 11:20 |  #1
After at least three years of hearing the arguments for and against DxO Optics, I finally decided to try it over the weekend. My initial conclusion is that its quite a good program once you get used to the interface.
However, from my tests using the default settings I've noticed what I can only describe as a Dxo "look." So here's my question; is it possible to apply lens/optical corrections ONLY when processing files in DxO?
Ideally I'd want these corrections to be output to a DNG for further processing in Lightroom/Photoshop. But as far as I can tell, other corrections such as Lighting, softness, etc. are also applied by default. Is it possible to turn those off? And yes, I already understand all the arguments about linear demosaics etc.
rzych
Feb 23, 2009 21:08 |  #2
DxO has a "no corrections" preset that you can apply to your raw files. Then just activate the Focusing Distance, Distortion, Lens Softness, and Chromatic Abberation panels. Export as a DNG and you should be good to go.
Rudy
10D, 5D, 17-40, 24-105
tzalman
Fatal attraction.
Feb 24, 2009 02:42 |  #3
F the C - Seems like a big expense for lens corrections only. I know you use Breeze Browser Pro, it contains PTLens corrections. Or the PTLens plugin for PS is only $25.
Elie / אלי
PixelMagic
Feb 24, 2009 08:47 |  #4
rzych wrote in post #7392120 (external link)
Thanks...that worked perfectly.
I figured out another way which is to turn off all the panel on the Prepare module then turn back on the lens correction options. But that still means a preset of some sort will be applied so yours is certainly the better option.
PixelMagic
Feb 24, 2009 08:51 |  #5
tzalman wrote in post #7394134 (external link)
It sure is; which is the reason I'm only "trialing" at this stage. BreezeBrowser does not have some very common lens in its database. For example, I have a Canon 70-200 f/2.8L (non-IS) and its not in the database.
I'm really impressed with DxO's lens corrections but the interface isn't very intuitive. I can see it having a place as a front-end to Lightroom but I don't particularly like the idea of linear DNG output.
1,213 views & 0 likes for this thread, 3 members have posted to it.
1064 guests, 104 members online
