Thread started 23 Feb 2009 (Monday) 14:30
What am I doing wrong?
sancho1983
Feb 23, 2009 14:30 |  #1
Hi there, am loving this site and have learnt a lot in the relatively short time i've been here, sometimes i get a bit disheartened with the quality of my shots, for example the one below
IMAGE: http://i635.photobucket.com/albums/uu79/sancho_1983/rutlandwater_57.jpg
I focused about a third of the way down the pine cone from the top, however the focus point seems to be in front of the cone completely! I thought the lens might be 'front focusing' (bad workman always blames his tools....) so i stopped it down a bit from wide open, f5.6 i believe, which i thought might compensate for any focusing problems
Another example
IMAGE: http://i635.photobucket.com/albums/uu79/sancho_1983/rutlandwater_68.jpg
I know it's technically/Compositio​nally (think i invented a word) not a good shot, but it doesn't seem very sharp either.
Both of the shots seem a bit...... meh. The colours seem odd. I shoot in Av always, manually select the focus point rather than recomposing and try not to use my lenses fully open, as they seem soft there. I always shoot in RAW then convert using ACR. No other pp has been done to either of these shots.
Am i wrong for jumping straight into using Av?, don't really want to use the green box. Perhaps i am expecting too much after looking at the professional shots on here.
Instagram (external link)
Https://bgsweddings.co​.uk (external link)
songexe
Feb 23, 2009 14:41 |  #2
What lens did you use?
There's nothing wrong with jumping straight into the semi-automatic modes at all!
Canon XSi | 18-55 IS | 85/1.8 | Manfrotto 790B
sancho1983
Feb 23, 2009 14:46 |  #3
Both with the 18-55IS, i had the 18-55 before and they were even worse!! Was pleased with the new lens, is definitely an improvement, just feel like i'm missing something....
What ISO should be acceptable with the 20d? Both are 400 which i didn't notice before, i always forget to change that!! But 400 should be ok right?
number ­ six
fully entitled to be jealous
Feb 23, 2009 15:00 |  #4
As you said, the top shot is front-focused. This may or may not be the fault of the equipment - at 55 mm, your DOF at f/5.6 isn't very deep and body motion can lead to an OOF shot.
Were these shots handheld? If so, try a tripod...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
number ­ six
Feb 23, 2009 15:02 |  #5
Oh, yeah: you asked about Av. It's the most useful mode, IMO. You should never need to go to the green box unless you're handing your camera to a novice.
-js
"Be seeing you."
Laramie
Still livin' the cowboylife
Feb 23, 2009 15:05 |  #6
Where did you focus on the second shot? The wood grain looks pretty sharp.
How were you standing/holding the camera for the first shot? I think your focus plane is tilted so that in front of the cone looks in focus along with the very tips of the cone.
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
Duncan ­ Frenz
Purposely evaded the TF
Feb 23, 2009 15:09 as a reply to  @ number six's post |  #7
Could you elaborate on how you focus? You say you manually select the focusing point rather than recompose. Using the center focusing point will provide more accurate focusing than any other point.
- Duncan
Gear_Mor
e than I need, Less than I want
Nonconformists are all alike.
I am not an expert, but I play one on the internet.:D
sancho1983
Feb 23, 2009 15:33 |  #8
number six wrote in post #7389387 (external link)
-js
Yes they were handheld, at 1/50 with IS is there still a risk of motion blur? I wouldn't say i'm unsteady, but have no frame of reference for it really!! :)
number six wrote in post #7389394 (external link)
-js
That's what i thought, I understand the effect of aperture, shutter speed, ISO etc. So i figure i'm ok to be let loose with Av :)
cowboylife wrote in post #7389431 (external link)
I suppose the post was about 5 feet high and i crouched down slightly (i'm 6ft 5) so i was pretty much head on, although i was above it
Duncan Frenz wrote in post #7389466 (external link)
Didn't realise the centre point was more accurate, for the second shot i composed the shot (as such) then changed the focus point to the one which would be at the centre of the flower head, which i believe it that case was the far right of the diamond. How would i have done it better? put the center AF point on the flower, half pressed, moved back to the position i took the shot in and fuly depressed it?
Thanks for the replies guys, i don't feel like giving up (yet!)
number ­ six
Feb 23, 2009 15:39 |  #9
sancho1983 wrote in post #7389648 (external link)
You're right, 1/50 with IS at 55 mm shouldn't show motion blur. And I don't see any in your picture.
IS is for side to side and up/down motion. I was talking about closer/further, which IS doesn't address. Photographers often sway a bit forward/backwards between focusing and tripping the shutter, giving a front- or back-focused result that's not the fault of the equipment. Hence my suggestion of a tripod for testing.
-js
"Be seeing you."
highbarger
Feb 23, 2009 15:44 |  #10
With a close shot like this, you're more likely to have an issue with changing your focus point simply by leaning forward or backward slightly.
Edit: number six beat me to it... great minds...
Duncan ­ Frenz
Feb 23, 2009 15:48 |  #11
The 20D has a high-precision cross-type sensor in the center position. It provides full cross-type performance with maximum apertures as small as f/5.6, yet it achieves up to 3 times the standard focusing precision when used with EF lenses featuring maximum apertures larger than or equal to f/2.8.
Yes, I would have useed the center focal point and recomposed if I was trying to achieve maximum sharpness.
- Duncan
Gear_Mor
tonylong
...winded
Gallery: 60 photos
Feb 23, 2009 15:52 |  #12
Duncan Frenz wrote in post #7389756 (external link)
Well, but tht depends on how close he was and what his aperture was. Shooting close up by focus and recompose can be a disaster (as is rocking back and forth).
OP, you might want to grab a tripod and try shots like that taken with a very sturdy support (you can turn the IS off for this). If you are getting a slow shutter speed, Mirror Lockup and a cable release are also your friends.
Once you take some tripod-mounted shots, you should get a much better idea of what to expect, and have some comparison stuff to bounce your hand-held shots off of.
Tony
sancho1983
Feb 23, 2009 15:53 |  #13
number six wrote in post #7389686 (external link)
-js
highbarger wrote in post #7389717 (external link)
Great minds think alike lol, i see what you mean now, will definitely bear that in mind, perhaps try something similar both with tripod and without. Thanks! :)
Will definitely do that too, is there a negative to doing it that way? Don't know why i don't really
tzalman
Fatal attraction.
Feb 23, 2009 16:51 |  #14
Yes, if the camera to subject distance is short it can cause a missed focus. Read this
http://www.visual-vacations.com …focus-recompose_sucks.htm (external link)
Elie / אלי
rral22
Feb 23, 2009 17:01 as a reply to  @ tzalman's post |  #15
If sharpness is the goal, the first thing to do is put the camera on a tripod. You will be astonished at how much a tripod will improve the quality of any lens, IS or no IS.
Once you have run several experiments on a tripod you will have a much more realistic impression of just how your lenses can work if you give them a chance.
3,036 views & 0 likes for this thread, 14 members have posted to it.
1065 guests, 104 members online
