I bought 430EXII, so I confused about auto zoom and manual zoom. For example: If I used lens kit 18-55, which is distance can I set for it?
Feb 26, 2009 10:18 | #1 I bought 430EXII, so I confused about auto zoom and manual zoom. For example: If I used lens kit 18-55, which is distance can I set for it? 5DsR, Rokinon FE 12 mm f/2.8, Canon 35 II f/1.4, Sigma 50mm f/1.4, MP-E 65mm,Canon 85mm f/1.4 L IS, Canon macro 100mm f/2.8, Canon 17-40mm f/4.0 L,Canon 24-70mm f/2.8 L, Canon 70-200 f/2.8 L, 580ex II.
msowsun "approx 8mm" More info | Feb 26, 2009 10:26 | #2 You should select "auto zoom" and leave it there. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Feb 26, 2009 10:43 | #3 Yep, I see. But the maximum zoom is 135mm. What happend when I use the zoom lens bigger 135mm? What happend if I set manual zoom 50mm when i use 18-55? 5DsR, Rokinon FE 12 mm f/2.8, Canon 35 II f/1.4, Sigma 50mm f/1.4, MP-E 65mm,Canon 85mm f/1.4 L IS, Canon macro 100mm f/2.8, Canon 17-40mm f/4.0 L,Canon 24-70mm f/2.8 L, Canon 70-200 f/2.8 L, 580ex II.
msowsun "approx 8mm" More info | Feb 26, 2009 10:56 | #4 The max zoom available on the 430EX II is 105mm. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
40Dude6aedyk Goldmember 1,064 posts Joined Jun 2008 More info | Feb 26, 2009 10:58 | #5 philubonmat wrote in post #7411121 Yep, I see. But the maximum zoom is 135mm. What happend when I use the zoom lens bigger 135mm? What happend if I set manual zoom 50mm when i use 18-55? LOL! Try it and tell us what happens. Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
msowsun "approx 8mm" More info | Feb 26, 2009 11:22 | #6 One more thing..... Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Feb 26, 2009 11:57 | #7 40Dude6aedyk wrote in post #7411237 LOL! Try it and tell us what happens. I mean, I confused between auto zoom and manual zoom. I don't know how to set distance in manual zoom mode. And I have given an example: If i set 50mm for manual zoom when i use 18-55 lens, what's happend with my picture? It's good or bad? 5DsR, Rokinon FE 12 mm f/2.8, Canon 35 II f/1.4, Sigma 50mm f/1.4, MP-E 65mm,Canon 85mm f/1.4 L IS, Canon macro 100mm f/2.8, Canon 17-40mm f/4.0 L,Canon 24-70mm f/2.8 L, Canon 70-200 f/2.8 L, 580ex II.
msowsun "approx 8mm" More info | Feb 26, 2009 11:59 | #8 It will depend on what focal length you have your 18-55mm lens set to. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Feb 26, 2009 12:17 | #9 Your mean. If I use manual zoom, i must be set distance for flash for every position in my lens? 5DsR, Rokinon FE 12 mm f/2.8, Canon 35 II f/1.4, Sigma 50mm f/1.4, MP-E 65mm,Canon 85mm f/1.4 L IS, Canon macro 100mm f/2.8, Canon 17-40mm f/4.0 L,Canon 24-70mm f/2.8 L, Canon 70-200 f/2.8 L, 580ex II.
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Feb 26, 2009 12:25 | #10 Phil, "If you're not having fun, your pictures will reflect that." - Joe McNally
40Dude6aedyk Goldmember 1,064 posts Joined Jun 2008 More info | Feb 26, 2009 12:31 | #11 philubonmat wrote in post #7411598 I mean, I confused between auto zoom and manual zoom. I don't know how to set distance in manual zoom mode. And I have given an example: If i set 50mm for manual zoom when i use 18-55 lens, what's happend with my picture? It's good or bad? Seriously, why can't you go try that yourself and tell us whether the picture is good or bad? Good or bad is so subjective and personal that you should be able to experiment and see what you like for yourself. I can understand that if you had to go to the dark room and develop film to see the results that it would be a pain, but with a digital camera it will take you less time to do the test shots than to read this message. And you will learn quite a lot by doing your own experiments ... I hope. Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
Feb 26, 2009 13:22 | #12 Curtis N wrote in post #7411749 Phil, The flash zoom setting simply changes the flash unit's coverage angle. It has nothing to do with distance (though it does affect the flash units maximum range). Zooming simply makes most efficient use of the light by covering an angle just large enough for your lens' field of view. This is my purpose. Because I don't know the effect of unit "mm" in flash, i think it's the distance can use of flash to subject. 5DsR, Rokinon FE 12 mm f/2.8, Canon 35 II f/1.4, Sigma 50mm f/1.4, MP-E 65mm,Canon 85mm f/1.4 L IS, Canon macro 100mm f/2.8, Canon 17-40mm f/4.0 L,Canon 24-70mm f/2.8 L, Canon 70-200 f/2.8 L, 580ex II.
msowsun "approx 8mm" More info | Feb 26, 2009 13:49 | #13 The "mm" on your flash refers to the length of the lens you are using. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Feb 26, 2009 13:52 | #14 Thanks so much msowsun!!! I got many lesson from this topic. 5DsR, Rokinon FE 12 mm f/2.8, Canon 35 II f/1.4, Sigma 50mm f/1.4, MP-E 65mm,Canon 85mm f/1.4 L IS, Canon macro 100mm f/2.8, Canon 17-40mm f/4.0 L,Canon 24-70mm f/2.8 L, Canon 70-200 f/2.8 L, 580ex II.
msowsun "approx 8mm" More info | Feb 26, 2009 13:53 | #15 You are welcome. I hope you got it now. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member is semonsters 1457 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
