If you select the quick dial wheel to select your chosen focus point how do you adjust your exposure compensation in av, tv modes, very interested to find this out .
tongard Senior Member More info | Feb 26, 2009 13:32 | #1 If you select the quick dial wheel to select your chosen focus point how do you adjust your exposure compensation in av, tv modes, very interested to find this out . Canon 6d, 7d2.
Mikkeln Mostly Lurking 10 posts Joined Feb 2009 Location: Southern Alberta More info | Feb 26, 2009 13:46 | #2 I believe you need to press the shutter button half way, then the wheel and dial revert back to their original uses ... I don't have my camera infront of me to check this right now so now you have me wondering. 40D, 17-85 kit, 50mm f1.8, 580EXII
Feb 26, 2009 13:53 | #3 Like wise i dont have my camera infront of me but i think i tried that , the only way i can seem to adjust the exposure compensation is to not select the quick dial wheel for focus point selection Canon 6d, 7d2.
sonic72 Senior Member 594 posts Likes: 1 Joined May 2007 Location: yorkshire,england More info | Feb 26, 2009 14:32 | #4 you need to press the focus select button then turn the top wheel. darrell j prest photography
hawk911 Cream of the Crop More info | Feb 26, 2009 15:00 | #5 you change the focus point button back and don't touch it again. HAWK Photography Gallery
Mikkeln Mostly Lurking 10 posts Joined Feb 2009 Location: Southern Alberta More info | Feb 26, 2009 19:45 | #6 tongard wrote in post #7412228 If you select the quick dial wheel to select your chosen focus point how do you adjust your exposure compensation in av, tv modes, very interested to find this out . Just got home and had to try this out ... after hitting the AF point selection/magnify button, you can use either the quick wheel or the main wheel to change the AF point ... then push the shutter button half way and the shutter speed or aperature can be adjusted with either the quick dial or main dial IF you have the on switch set to the SECOND ON position (_/) ... The quick dial will not work if you are only on the ON position. 40D, 17-85 kit, 50mm f1.8, 580EXII
| Latest registered member is Niagara Wedding Photographer 1440 guests, 145 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
