Thread started 27 Feb 2009 (Friday) 10:35
Cs4 ask for license agreement each time?
[shingo]
Feb 27, 2009 10:35 |  #1
Is this normal? After I entered my license key, photoshop did start without a hitch, but when I close the software, each time I start it again, I have to accept the license agreement?
Anyone have a solution?
CAL ­ Imagery
Feb 27, 2009 10:37 |  #2
I haven't.
Christian
iof
Joined Mar 2004
Feb 27, 2009 10:59 |  #3
Vista I assume? UAC "protecting" you?
Try this:
Right click start up entry and choose "run as administrator".
Enter key.
Should start normally from then on.
Ron.
5D,20D, D60, Elan 7, Canon stuff from the 70's, Pentax stuff from the 60's, other stuff.
NinetyEight
"Banned for life"
Feb 27, 2009 11:31 |  #4
As iof said, Sounds like Vista needs to be in 'Administrator mode' to enable the software to 'flag' that you have accepted to agreement.
Kev
HankScorpio
Feb 27, 2009 12:42 |  #5
Vista doesn't require you to run PS as Admin. In fact, I've never had to run anything as Admin.
Ty deleteing the cache.db file from C:\Program Files (x86)\Common Files\Adobe\Adobe PCD\cache
for 64bit
or just
C:\Program Files\Common Files\Adobe\Adobe PCD\cache
if you are using 32bit only.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
[shingo]
Feb 27, 2009 13:30 |  #6
What's funny is that the 32bits ask to read the license agreement everytime and the 64 bit work perfectly.
I will try hank trick as soon as I get home.
[shingo]
Feb 27, 2009 17:53 |  #7
woohoo it's working now :) thanks
HankScorpio
Feb 27, 2009 17:58 |  #8
It doesn't happen often (rarely ever) but sometimes my knowledge both astounds and frightens me :D
[shingo]
Feb 27, 2009 18:36 |  #9
If you are so knowledgable, how to modify lightroom to use photoshop X32 instead of X64.
HankScorpio
Feb 28, 2009 03:15 |  #10
Open Lightroom preferences, select "External Editing" tab.
Under "Additional External Editor" click the "choose" button and navigate to CS4 32bit.
Select your desired editing file format, I'd go with TIFF, ProPhoto RGB, 16bit, no compression but whatever you want is OK too.
Click the "Preset" Drop down and select "save current setting as new preset". Call it CS4 32bit or something.
Now you have the 32bit option under the usual "Edit in" menu item or if that is your only external editor listed then Ctrl+Alt+E is the shortcut.
emreplt
1 post
Dec 05, 2009 03:20 as a reply to  @ HankScorpio's post |  #11
go installation directory, find adobe_eula.dll
rename adobe_eula.dll to adobe_eula.old
MattRaizoku
Mar 25, 2010 13:40 |  #12
emreplt wrote in post #9138881 (external link)
This worked first time, thanks...
flickr (external link) | Canon EOS 7D | Canon EF 50mm F1.4 | Sigma 10-20mm F4-5.6 | Canon 24-105 F4 L |
A hobby that leaves my wallet terribly empty each lense.
TTk
Mar 25, 2010 13:44 as a reply to  @ MattRaizoku's post |  #13
So helpful this forum..:D:D
Terry.:cool:
http://www.terrykirton.co/ (external link)
http://www.ttkphotogra​phy.com/ (external link)
http://www.langtoftpho​tography.com/ (external link)
 (external link)
SnapsbyPoteat
Mar 25, 2010 17:48 |  #14
my photoshop elements 8 does the same things, I had never tried to figure out why. I had always been able to close it our and reopen it just fine.
Gear list: Canon 5D Mk II, 7D tokina 11-16/2.8, Sigma 30 1.4 , Canon 50 1.2 L, 85 1.8,100 2.8 L macro, 580ex,
www.snapsbypoteat.com (external link) . Facebook Page (external link)The Blog (external link)
The wedding page www.melaniepoteat.com (external link)
trailguy
Oct 31, 2010 17:50 as a reply to  @ SnapsbyPoteat's post |  #15
CS4 license pop up
When I open my CS4 extended, I get two pop up's calling themselves FNLPLicensingService.e​xe.
I've been allowing it but have not checked 'Allow'.
Can someone assure me it's ok to tell my Armor to allow it automatically?
Perfectionism is the highest form of self-abuse
"Best wide-angle lens? Two steps backward"
Ernst Hass 1952
25,565 views & 0 likes for this thread
Latest registered member is Espen Hestdahl
1966 guests, 207 members online
