Thread started 28 Feb 2009 (Saturday) 16:51
580 EX II Standby timer
dcsmith40D
Feb 28, 2009 16:51 |  #1
I have the 580 ex II and the Cybersync radio trigger. It works great. The only thing that doesn't work so great is the speedlite going into standby mode. I lost the book on the 580; I'm sure there is a way to change the length of time before it hibernates.
I would appreciate any help.
David
Canon 40D; 50 f1.8, 70-200 f2.8 IS L, 580 EX II, 1.4 TC, 24-70 f2.8 L, (2) 430 EX II
David
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Feb 28, 2009 17:37 |  #2
Set Custom Function 01 to 1 - Disable Auto Power.
If the 40D Flash Control Menu item gives access to the Flash's Custom Functions, use that to set.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
dcsmith40D
Feb 28, 2009 17:46 |  #3
CliveyBoy wrote in post #7426983 (external link)
Thanks for the response. I don't know how to set the Custom Function on the speedlite. When I hit the Light/C.Fn button the light toggles on and off. There is a menu for controlling the external flash, however, it doesn't work for off camera flash. At least that I know of. Any further tips would be appreciated.
David
CliveyBoy
Joined Nov 2005
Feb 28, 2009 18:03 |  #4
Sorry, meant to add that - hold that Light/C.Fn button down until a C.Fn symbol appears in the bottom left of the display.
Turn the large dial until the required function is displayed. Press the Set button in the middle, dial to the value, press Set again.
Or, put the flash on the camera to set the menu. The menu wording fully details the functions and their setting values.
PacAce
Joined Feb 2003
Feb 28, 2009 18:19 |  #5
dcsmith40D wrote in post #7427028 (external link)
What you need to do is mount the flash in the camera hotshoe, then set the custom function. You can then take it off camera. Setting the custom function via the camera makes it very easy because the menu will tell you exactly what function you are setting without needing to guess or having had it memorized. :)
...Leo
dcsmith40D
Feb 28, 2009 19:13 |  #6
Thanks, both of you. I did in on the camera. That should make off camera flashing much easier.
Thanks,
David
David
motleypixel
Feb 28, 2009 20:14 |  #7
Kewl...I suppose this works for the 580ex I too? I'm sitting here right now and looking at my 430EX I also, and it has a C.Fn button too...boy I hope I can disable sleep on it too!
-Roy
Minolta Rokkor and Canon can live together in harmony. (external link)http://vimeo.com/14891​384 (external link)
PacAce
Joined Feb 2003
Feb 28, 2009 21:23 |  #8
motleypixel wrote in post #7427710 (external link)
-Roy
Yes, you can set the custom function on the 580EX to not go to sleep but it's not with the same custom function number. On the 580EX, sleep mode is turned off with C.Fn-14 set to 1. On the 430EX, it's C.Fn-01.
...Leo
Yohan ­ Pamudji
Mar 01, 2009 00:52 |  #9
http://www.eosdoc.com/​manuals/?q=580EXII* (external link)
Teach a man to fish, and so on.
dcsmith40D
Mar 01, 2009 09:50 |  #10
Yohan Pamudji wrote in post #7429066 (external link)
Thanks. That helps a lot too. Although sometimes it seems less confusing when somebody else finds the bait and puts it on the hook.:rolleyes:
David
8,494 views & 0 likes for this thread, 5 members have posted to it.
953 guests, 182 members online
