Thread started 28 Feb 2009 (Saturday) 17:21
430ex vs 580ex
caroleigh
Feb 28, 2009 17:21 |  #1
I know nothing about flashes. I was wondering if there is a big difference between the two? The 580ex is the first version, not the II.
7D / 40D / 70-200mm 2.8L / Tamron 28-75mm 2.8 / 50mm 1.8 / Canon 85mm F/1.8 / kenko 1.4 / 580ex
e.omega
Feb 28, 2009 17:23 |  #2
The 430ex I or II?
T2i | 30 f/1.4 | 18-55 IS| 430EX II |
caroleigh
Feb 28, 2009 17:26 |  #3
Oh, sorry. Just says 430ex so I suppose the I
e.omega wrote in post #7426916 (external link)
The 430ex I or II?
snakekid
Feb 28, 2009 17:28 |  #4
compare the guide number thats how you can tell power. plus you can use the 580 to trigger 430s
-Will
40d, tamron 17-50mm, 85mm 1.8. a ton of flashes and cybersyncs.
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Feb 28, 2009 17:32 |  #5
The 430EX has a guide number of 43 metres, and the 580EX a GN of 58 metres, at best.
Apart from the extra light, the 580EX can be used as a master to control another Canon-compatible flash.
Of course, the best would be to get both!
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
caroleigh
Feb 28, 2009 17:33 |  #6
I have both. I have no idea how to use either. I'm looking to part with one as I have no need to keep both... just haven't figured out which I am keeping yet.
CliveyBoy wrote in post #7426962 (external link)
CliveyBoy
Joined Nov 2005
Feb 28, 2009 18:13 |  #7
Ah! You might be glad to have kept both, once you discover the versatility they give you.
I suggest that you spend time reading through Lighting 101 and 102 at:
http://strobist.blogsp​ot.com/2006/03/lightin​g-101.html (external link)
I found the first four paragraphs of Lighting 102 - 3.1 was one of those "Aha!" moments for me.
caroleigh
Feb 28, 2009 19:49 |  #8
I can't justify keeping both :( One has to go. I don't use flash often. I need to figure out if it's worth it to me to keep the 580ex or just stay with the 430ex.
Thanks for the link, looks like interesting read!
CliveyBoy wrote in post #7427139 (external link)
yogestee
Mar 01, 2009 06:24 |  #9
caroleigh wrote in post #7427582 (external link)
Carol,,keep the 580EX..
Jurgen
Ukuleleman
Mar 01, 2009 08:43 |  #10
The difference in power between the two would be amplified when bouncing the flash or using an umbrella, keep the 580.
There are no shortcuts to any place worth going to
https://photography-on-the.net …p?p=2701981&pos​tcount=461
http://ukuleleman.zenf​olio.com/ (external link)
scorpio_e
Mar 01, 2009 17:06 |  #11
If you are not using flash often,keep the 430.It is smaller.
www.steelcityphotograp​hy.com (external link)
CanonLaw
Joined Jun 2005
Mar 01, 2009 18:42 |  #12
Keep the 580. There are things the 430 cant do that the 580 can. And the 580 is not that much bigger.
onlypars
Mar 01, 2009 20:02 |  #13
I have both the 430 and 580 version 1's and like you, I don't use either very much. However, I am starting to learn about the new doors that will open once I learn how to use these together. If you don't need the money, then keep both. If you onlt want one, then keep the 580.
1DMkIIN, 70-200 2.8L IS, 100-400IS L, 24-105L, 100 2.8, Canon 50 1.4,Tokina 28-80 2.8, 430EX, 580EX, Quantum Turbo, 1.4 x EF II, 2X EF
Need to sell 20D, 17-85IS, BGE2, 17-85 IS, 2x EF
WISHLIST: 1.4X IIx2, 24-70 2.8 L, 85 1.8, 135 f2
2,177 views & 0 likes for this thread, 9 members have posted to it.
430ex vs 580ex
1019 guests, 144 members online
