Thread started 01 Mar 2009 (Sunday) 10:16
40D flash doesn't pop up...
DDA
Formerly foolish member. Waiting for new title.
Location: Between a cow, a clock and tons of chocolate...
Mar 01, 2009 10:16 |  #1
I don't use the built-in flash a lot, I usually prefer my Sigma 500....
However, as I didn't have my external flash with me yeterday, I wanted to take a few shots using the built-in flash. That's when I discovered that I couldn't make it pop up. :shock:
The camera simply does not seem to realize it has a built-in flash (maybe it knows it's not really useful :p) Whatever I do, it doesn't react and i don't hear anything like the camera trying to open the flash. I've tried using the force flash button in Av, Tv, M and P modes, or using green box night portraits and so on...
Couls I have changed a setting somewhere which could cause this behaviour? Or is the camera good for a trip to Canon?
Thanks for your help ;-)a
DDA - C&C welcomed and encouraged
“A technically perfect photograph can be the world’s most boring picture.” (Andreas Feininger)
An empty account and a lack of talent (external link)
jwcdds
Gallery: 1924 photos
Best ofs: 8
Joined Aug 2004
Mar 01, 2009 10:22 |  #2
Silly question but I have to ask. I'm assuming you pressed the flash button already?
Julian
thomascanty
Bold. Pink.
Gone, but not forgotten.
Joined Mar 2003
Mar 01, 2009 10:28 |  #3
Mine is the same way. I have to flip it up with a pocket knife as I press the button. I've been told this is a common problem with Canon SLRs. My camera is still under warranty, but since I almost never use the pop-up flash I haven't decided if I'm going to get it fixed.
Hermeto
Mar 01, 2009 10:28 |  #4
Check hot shoe rails first.
Underneath the spring on one of them, there is a tiny micro switch that tells the camera not to lift built in flash when external flash is mounted.
Sometimes, that little switch gets stuck.
Jerk it a little bit with something sharp, like toothpick, work it out couple of times, pressing the flash button at the same time..
captclick
Mar 01, 2009 10:49 |  #5
Check the flash menu and make sure you didn't disable it there.
Canon 1DMKIII : Canon EOS 40D : EF 24-105L : EF 70-200L 2.8 IS : EF 135L : EF 300L 2.8 IS : EF 1.4x II : 580EXII : Sekonic L-358 : Big Wishlist
DDA
Mar 01, 2009 11:01 |  #6
jwcdds wrote in post #7430645 (external link)
Done
Hermeto wrote in post #7430685 (external link)
Done and not stuck...
captclick wrote in post #7430781 (external link)
Where could this be hiding in the menu. I had a look at the menu but didn't find anything which seemed to disable flash :o Is there a specific function that I oversaw? :o :o
DDA
Mar 01, 2009 11:03 |  #7
thomascanty wrote in post #7430684 (external link)
I can't flip it up anymore while pressing the button as without pressing. Pressing the button really seems to have no effect at all.... (not even the slightest noise of flash trying to open. :rolleyes:)
CrazieCricket
Stupid wine.... *kicks box*
Mar 01, 2009 11:11 |  #8
DDA wrote in post #7430836 (external link)
Go to flash control, flash firing, and enable.
Paula
jwcdds
Best ofs: 8
Joined Aug 2004
Mar 01, 2009 11:17 |  #9
^ Don't think that matters. I just disabled mine and I can still get my flash to pop up w/ the button.
Me thinks DDA's got a bad pop-up switch.
Julian
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 01, 2009 11:25 |  #10
DDA wrote in post #7430847 (external link)
How about green box mode? It should pop up automatically.
If it doesn't then I am quite sure switch in the hotshoe is sensing an external flash.
Here is a link that might help: http://www.conraderb.c​om/flashrepair/ (external link)
IMAGE: http://www.conraderb.com/flashrepair/peeking2.jpg
CrazieCricket
Mar 01, 2009 11:36 |  #11
jwcdds wrote in post #7430914 (external link)
Right you are. I should of checked that. :oops:
Paula
DDA
Mar 01, 2009 11:46 as a reply to  @ CrazieCricket's post |  #12
msowsun wrote in post #7430957 (external link)
Done and doesn't work and no, the switch isn't sensing an external flash...
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 01, 2009 12:11 |  #13
When you go into the in-camera Flash control menu, (Built-in flash func. setting) what does it look like?
It should read....
- (Flash mode E-TTL II) (all grayed out) (at least it does on mine???)
- Shutter Sync. 1st curtain
- Flash exp. comp "0"
- E-TTL II Evaluative
If you see:
This menu cannot be
displayed. External flash
is attached
Then you have a problem with the external flash sensor switch.
DDA
Mar 01, 2009 13:45 |  #14
msowsun wrote in post #7431168 (external link)
It should read....
If you see:
:o Yep, that's it :o The switch looked perfectly normal from outside though. I managed to unlock it with a needle. I'll do a few tries and if it gets stuck everytime I attach the external flash, it'll make a trip to Canon!
Thanks a lot for your help :mrgreen:
thomascanty
Bold. Pink.
Joined Mar 2003
Mar 01, 2009 13:57 |  #15
It should read....
That's what mine shows. The problem I always had was that the internal flash was just physically stuck. If I press the button I could hear the camera go "Ssssshhhhhk... Ssssshhhhhk... Ssssshhhhhk... ", then an error would show on the LCD and I'd have to turn the camera off/on to be able to use it again. I just grabbed it so I could post the exact error message I've been getting, but now the flash pops up just fine. WTH?!?
Funny... I've had the thing 10 months and the damn flash has never worked until now when I actually wanted it to fail. :rolleyes:
4,295 views & 0 likes for this thread, 9 members have posted to it.
670 guests, 126 members online
