I'm using the 550EX on my 5D2, but can't get the flash to work as I think it should. All flash images (on P for instance) are underexposed (maximun throw about 3 metres, ISO200) but all exposures are 1/60 at f/4, regardless of scene or distance, as if the sync is slightly wrong.
The key may be that I can't get to External Speedlite Control C.Fns. I can get to Flash function settings, but when I try Flash C.Fn Settings I get the message "This menu cannot be displayed. Incompatible flash or flash's power is turned off". I get the same message when I try to Clear all Speedlite C.Fns.
Before you ask, the flash is in the hot shoe, switched on and fully charged with fresh batteries, and works fine on my old 10D.
Is the 550EX actually NOT compatible with the 5D Mk II? Seems I can only use it on manual. I have a call out with Canon at the moment, but only head-scratching from them so far.
Can anyone shed any light?
