Thread started 03 Mar 2009 (Tuesday) 16:37
Expodisc or baLens?
Kris_2020
Mar 03, 2009 16:37 |  #1
Anyone use any of these?
I am interested in baLens 77mm White Balance Lens Cap or the expodisc. Which is recommended? Expodisc also has a few different type so which one would be best for all type of photography?
Canon 5D IV | Canon 70-200mm f/2.8 IS L Mark 2 | Canon 85mm f/1.8 | 580 EX II
Flickr Site (external link)
SkipD
Joined Dec 2002
Mar 03, 2009 16:41 |  #2
You would be much better off with a good gray card. The best of them today is the WhiBal. This will cost you far less than the "magic lenses" and be much more versatile.
As an example of what a gray card can do that you cannot do with the lenses: You can place a gray card in a scene for a test shot, shoot in RAW mode, and do all your color correction VERY easily during RAW conversion post-processing.
A gray card can also be a valuable tool for exposure control. Using it will let you measure the amount of light falling on a subject (rather than light reflecting from it).
Skip Douglas
Sean
Mar 04, 2009 07:03 |  #3
SkipD wrote in post #7448012 (external link)
I've done well with my grey card. My only problem is holding it infront of the cam on a long lens. BLAH.
Canon 50D - 17-55mm F2.8 IS - 300mm F4L IS - 70-200mm F4L IS - 50mm F1.8 - 580EX II & 430EX - Full Gear Listing
Flickr (external link) - C&C Always welcome.
jhom
Mar 04, 2009 12:44 |  #4
I agree about a grey card such as the WhiBal. It is convenient to use. Just throw it out on the ground in front of you and take the shot. It doesn't need to be in focus. Then correct your images in post. White balancing a snap.
Jim
tunin
Mar 04, 2009 14:00 |  #5
I have the expo disc and i like it alot, I snap it on, no need to worry about the reflections, shade.... just snap and go... It is a bit on the steep part price wise but I went for it and I did not regret it.
On another note, most of my lenses are 77mm but the 16-35 (82mm), I wish I got the 82mm expo disk... I could have used it on the 82 and 77 for a few more $
I am not young enough to know everything. O.W.
yokotas13
Mar 04, 2009 21:33 |  #6
just get a reducer. its not going to affect your stuff.
-Grant
[URL=http://photograph​y-on-the.net/forum/showpost​.php?p=7493258&postcou​nt=1706]Gear List
check the blog- www.wagonofdoom.wordpr​ess.com (external link)
geogecko
Jun 14, 2009 16:05 |  #7
I also had this question. I read an article where the writer was bashing the balens when it first came out. The interesting thing was the comments on the article.
People said yes, a gray card is probably the way to go if you want to do post processing, but if you are like me, and several others, and would rather get it right in camera, and spend less time in front of the computer, then it seems like one of these WB caps/lenses would be a real time saver.
Just thought I'd throw that out there, and see if we can get some responses on the original post, because I am interested.
So, if you were to not want to do post processing, would you still be better off with a gray card, or one of the WB lenses?
| GEAR | FEEDBACK |
Jon
Joined Jun 2004
Jun 14, 2009 17:10 |  #8
With a grey card. An ExpoDisc is supposed to be pointed at the light source, and that can be difficult if you're in mixed lighting conditions. A grey card is receiving whatever mix of light your subject is, so it's more likely to cope with a mix of light sources.
Jon
Cocker Spaniels
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 14, 2009 17:30 |  #9
Melitta... :)
CDS' HOT LINKS
geogecko
Jun 14, 2009 21:43 |  #10
So, you are saying to drink coffee to stay up late editing photos?
| GEAR | FEEDBACK |
sapearl
Gallery: 243 photos
Jun 14, 2009 22:17 |  #11
Not necessarily - "picture this".... if you are using the lens cap/Expodisc and are photographing a group, you would have to go to the position of the group and point the camera back to where you will be standing when you snap the picture. This may or may not be practical. Also, you may get some ribbing from the group - "Dude, we're over here ;)."
Now, if you are doing a scenic type shot, and the light is pretty uniformly the same everywhere, you can point the disk anywhere and get an accurate reading. But if it's a sunny day, or cloudy, etc., you really don't need it as those particular WB settings will get you in the ballpark.
The problem as has been pointed out, is mixed light settings. These can be shots indoors with windowlight mixing with lamplight mixing with flash. I've seen people use the disk/cap type product in the studio where things are fairly controlled and static.
I like my gray card or white disk. But then I shoot RAW and use the eyedropper to adjust WB in ACR :D. - Stu
geogecko wrote in post #8110482 (external link)
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
sapearl
Gallery: 243 photos
Jun 14, 2009 22:19 |  #12
What exactly is a reducer?
yokotas13 wrote in post #7457055 (external link)
JHunter
Jun 15, 2009 00:24 |  #13
sapearl wrote in post #8110664 (external link)
Also known as a step-down ring, will give you 77mm filter threads on your 82mm lens. No optics or anything, so its not tremendously useful outside of this, unless you intend to crop images all the time.
http://www.bhphotovide​o.com …_Step_Down_Ring​_Lens.html (external link)
Jack
Eos 1d Mark IV | Eos 1D Mark IIn | Eos 1v |24-70 f/2.8 L | 70-200 f/2.8 L IS | 100-400 f/4.5-5.6 L IS| 300/2.8 L IS | 430EX | 580EX II
http://www.jackhunterp​hoto.com (external link)
sapearl
Gallery: 243 photos
Jun 15, 2009 05:22 |  #14
That's pretty much what I thought, and couldn't see how that would aid in WB.
JHunter wrote in post #8111324 (external link)
geogecko
Jun 15, 2009 08:11 |  #15
The reducer would allow you to use your 77mm WB lens on the 82mm lens. If I remember correctly, most cameras use only the center circle (spot) for it's custom white balance setting. So if you had a reducer, and could see the reducer in the picture, I wouldn't think it would affect your WB picture...but I could be wrong, I am still a newbie.
| GEAR | FEEDBACK |
6,029 views & 0 likes for this thread, 11 members have posted to it.
Expodisc or baLens?
1757 guests, 176 members online
