Thread started 03 Mar 2009 (Tuesday) 17:30
question about resolution size and printing
brit84
Mar 03, 2009 17:30 |  #1
Im not sure how to I should size my prints before going to costco and getting them made. Im looking at getting some 4x6 made for now.
Should I:
1) make high resolution JPEGs that are the same size as the RAWs (in other words not resize anything, keep quality at 10, etc). In this case the costco soft ware would "squish" the file into a 4X6....right?
or
2) resize the images to smaller JPEGs to the size I intend to print (4x6), keeping aspect ratio, quality 10 etc.
What are the bad/good of each?
Also, should I change the DPI to anything other then 350?
Thanks all,
Andrew
5DIII/grip |5DII/grip | 40D/grip | 17-40L| 24-70L 2.8 II|70-200L IS f2.8 II | 580EXII x2 | Lensbaby composer | Benro 358 w/ Q3 | 2 Einsteins/Vagabond mini.
Facebook (external link)
Website (external link)
Damo77
Mar 03, 2009 17:43 |  #2
350 seems a little higher than necessary - I would say that 300 would suffice. Mind you, if you choose Option (1), then the resolution is irrelevant, of course.
My choice is always Option (2), because I like to be able to accurately sharpen my files at print size. However, other people will tell you that Option (1) is better, because it avoids double-resampling of your pixels.
Damien
Website (external link) | Facebook (external link)
brit84
Mar 03, 2009 17:52 |  #3
thanks,
should dpi be changed with the size of image printed?
Damo77
Mar 03, 2009 17:58 |  #4
Well, the only difference between Options (1) and (2) is the specification of a PPI value. If you choose (2) and make your photos 6x4, but don't specify a resolution, then the end result is the same as (1).
So yes, if you choose (2), you need to not only set the width and height, but the resolution as well.
Damien
egordon99
Mar 03, 2009 19:42 as a reply to  @ Damo77's post |  #5
I ALWAYS send the full resolution JPGs to Costco, even for little 4x6 prints. They must love me :lol:
And I do Quality 12 :)
EOS_JD
Mar 03, 2009 19:53 |  #6
When exporting my image, I output at the required size in pixels. Remember it's not dots per inch but PIXELS per inch. THere is a difference - although in this case I accept we are all meaning the same thing.
Printers print in dpi but images are made of pixels and resolution is measured in ppi.
A 6x4 @300ppi therefore is 6x300=1800 pixels by 4x300 = 1200pixels.
Resize your images to 1800x1200 and you will have the correct size to print your 6x4s at the optimum resolution for print. I never go above 300ppi and often print at 240ppi - the human eye would struggle to see the difference.
With regards to jpg quality, if you save the image out straight from the raw, 10 is fine and you will see no difference in the look of the image but you will see a dramatic reduction in the size (which can be good).
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
brit84
Mar 04, 2009 15:20 |  #7
thanks all, got the prints yesterday was pleased to see them very close in color to my monitor. A little noise becasue of my crops, but holding them a little futher away from my face they looked fine.
781 views & 0 likes for this thread
Latest registered member is heflerbj
891 guests, 323 members online
