Thread started 03 Mar 2009 (Tuesday) 21:13
2nd hand lens, how to check IS?
dsldub
Mar 03, 2009 21:13 |  #1
When buying a second hand lens with IS, how to check for IS operation, or if it's working properly?
Thanks.
|Canon 30D|
| EF-S 10-22 USM | EF-S 18-55 IS | EF-S 55-250 IS | EF 50 1.8 II |
flickr  (external link)Gear Listhttps://photography-on-the.net …?p=7832996&post​count=1782
nureality
Mar 03, 2009 21:29 |  #2
Turn it on, and shoot at a speed 2-3 stops slower than you normally would shoot at handheld.
i.e. if you can shoot your 50/1.8 @ 1/60 handheld, try shooting the 18-55IS @ 50mm 1/8 - 1/15, if IS is working, you should get a steady shot.
Alan "NuReality" Fronshtein
Gear List | PBase |  (external link)flickr (external link)
Lots of Fun, Lots of Laughs, Happy Trigger Finger!
Vascilli
Mar 03, 2009 23:39 |  #3
Hold your ear up to the lens, usually you'll hear a faint whine of the IS unit when it engages. On Sigma OS units you can hear it in a normal shooting position.
Flickr (external link) | Gear List
Fedxpress
Mar 04, 2009 00:09 |  #4
On a long tele just hold it up with out the IS on and do center spot focus so or at least look at the center spot and try and hold it on a subject. Then turn on the is and try again.
With out the IS with the 100-400 I can keep it within a few feet, Turn in on and I can nail the center spot. If it isn't working you should see a lot of movement in the view finder. The listen for grinding or unusually noise coming from the frame.
Fedxpress
1D Mark III, XTi, 16-35 f2.8L ,24-105 F4.0Lis, 28-135 3.5 is, 50 f1.8, 70-200 f2.8IIL is,100-400, Kenko Pro300, 430EXII
winmazing
Mar 04, 2009 00:41 as a reply to  @ Fedxpress's post |  #5
I tested my used 17-55 IS by listening very closely to the barrel while pressing the shutter button half-way. You should hear a whirling noise. If the IS is off, there will be no whirling noise. It might be difficult to listen at first so make sure you're in a quiet environment.
Shutterstock (external link) | flickr (external link) | Canon EOS 5D MK II | Fujifilm X-T1
AF: Canon EF 70-200mm F/4L IS, Sigma 35mm f/1.4
MF:
Mir-24H 35mm f/2.0, Pentax Super Takumar 50mm f/1.4, Olympus OM Zuiko Auto-W 24m f/2.8
DreDaze
Gallery: 49 photos
Mar 04, 2009 00:59 |  #6
if you can get your hands on a camera with live view...it's by far the easiest way...zoom in 10X magnification...that baby steadies right up
Andre or Dre
gear list
Instagram (external link)
Canon-guy
1 post
Mar 04, 2009 07:10 as a reply to  @ DreDaze's post |  #7
Getting a defective Canon lens would be very, very annoying. I've fortunately never had a problem with it.
Marquita Jensen
A Cannon lens (external link) super lenses (external link) fan.
Fedxpress
Mar 04, 2009 08:33 |  #8
The only problem with holding it up to your ear and listening is that this just let you hear the motor run. Not is it is working and holding the frame steady like it is suppose to do.
I can see it work on my 70-200, and 100-400.
Fedxpress
dsldub
Mar 04, 2009 21:06 |  #9
Will try all the suggestions.
|Canon 30D|
1,290 views & 0 likes for this thread, 7 members have posted to it.
1172 guests, 164 members online
