FORUMS Photography Talk by Genre Sports Talk
Thread started 06 Mar 2009 (Friday) 13:29
Baseball with a 7-200 2.8 IS IS on or off??
TheFloridaShooter
Mar 06, 2009 13:29 |  #1
Ok here goes. I haven't been very happy with the results I'm getting with my 50D and the 70-200 2.8 IS lens. I received a nice PM from someone that said I should try turning the IS off. If you keep IS on what Mode are you using? I or II???
I'd like to know if you guys shoot with the IS off or on. IF you can post some photos as an example. Also, please feel free to offer any other assistance.
1Dx MKII | 1Dx | 5D MKIV | 5D MKIII | 5Ds r | 5Ds | 7D MKII | 7D | G16 | G3x | EOS M & M3 | 800 f5.6 | 600 f4 | 400 f2.8 | 300 f2.8 | 200-400 f4 | 100-400 f4.5 - 5.6 II x 2 | 70-200 f2.8 | 14 f2.8 II | 50 f1.2 | 50 1.4 | 85 f1.2 | 135 f2 | 24-70 f2.8 II | 11-24 f4 | 35 f1.4 II | Pentax 645Z | SMC Pentax-DA 645 25mm F4 AL | SMC Pentax-D FA 645 55mm F2.8 AL | Pentax 90mm f/2.8 D FA 645 Macro ED AW SR | SMC Pentax-D FA 645 200mm f/4 IF | SMC Pentax-D FA 645 300mm f/4 ED IF | SMC FA 645 400mm f/5.6 ED IF Lens
AdamLewis
Mar 06, 2009 13:40 |  #2
Unless your IS is malfunctioning, it is not the fault behind whatever results you are getting.
To answer your question though, when I shoot with my 70-200 I turn it off unless I need it. I simply dont like having it spin up all the time when I dont need it to. All of the superteles though, I leave it on simply to help stabilize the viewfinder.
MJPhotos24
Joined Nov 2005
Mar 06, 2009 14:31 |  #3
Very rarely use IS, honestly don't remember the last time I used it but think it was a couple seasons ago when I wasn't too balanced. Read the manual because it explains the use and reasons behind IS.
Freelance Photographer & Co-founder of Four Seam Images
Mike Janes Photography (external link) - Four Seam Images LLC (external link)
FSI is a baseball oriented photo agency and official licensee of MiLB/MLB.
@FourSeamImages (instagram/twitter)
@MikeJanesPhotography (instagram)
@MikeJanesPhotog (twitter)
40Dude6aedyk
Mar 06, 2009 14:40 as a reply to  @ MJPhotos24's post |  #4
If my SS is 1/1000th or so, I usually turn it off. If my SS is 1/60th or so, I usually turn it on.
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
matonanjin
Mar 06, 2009 14:43 |  #5
Shooting baseball, or any sports, you need a fast enough shutter speed to stop action. That means a shutter speed of at least 1/500 sec, preferably faster. IS provides no benefit at that high of shutter speed.
As Adam said, if you are disatisfied with your results it is not the fault of IS.
For outdoor sports I use a 70-200 F4 NON IS. for indoor sports I use various fast primes all non IS.
My Web Site (external link)
My Equine Photography Blog (external link)
My Stuff and Feedback
DDCSD
GIVIN' GOOD KARMA
Mar 06, 2009 15:06 |  #6
Well, if you aren't letting the IS spin up before you trip the shutter you could be causing some issues. The IS needs a second or two to figure out what it is trying to counter, so if you just push the shutter button down and not allowing the IS to settle, you are actually inducing "camera shake" into your images.
IS is intended to help reduce the effects of camera shake when you are trying to keep the camera/lens steady. If you're moving the lens on purpose, there no reason to have IS on, since it will be attempting to counter the motions that you making even though you are doing it on purpose.
The exception is when you are trying to pan. Then you can leave the IS on mode 2. Mode 2 will only counter horizontal movements, not vertical movements.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
jmanser
Joined Feb 2006
Dec 11, 2010 09:50 as a reply to  @ DDCSD's post |  #7
Wow, great information! I'm looking to buy a 70-200, and couldn't decided whether or not the IS was important for me.
This helps me make my mind up (I think) :)
Canon 20D, 30D
Canon EF-S 17-85 IS USM, Canon EF 28-200mm
Canon EF 85MM F/1.8 USM
Canon Speedlight 580EX Flash
Dyna-Lite 400 w/s kit 2 strobes with umbrellas.
1,842 views & 0 likes for this thread
Latest registered member is dayuan99
868 guests, 323 members online
