Thread started 07 Mar 2009 (Saturday) 14:45
The ultimate macro setup?
gregpphoto
Mar 07, 2009 14:45 |  #1
I currently do a lot of reverse macro work, and I'm getting close to 5x magnification if not more with a single reversed EF 17-40 f/4L. However, I want to get much closer. I'm looking at getting into microscopy, but before I do, I want to take the camera as far as possible. So,
Camera -> Extension tubes -> 1.4x teleconverter -> EF 70-200 f/2.8L -> EF 17-40 f/4L (reversed)
I have no idea if this will work or how well if it does, but since I own both lenses and I want a teleconverter and extension tubes anyway, I'm gonna give it a go as soon as I get the converter and the tubes. Any thoughts, ways to make it better or more microscopic?
Also, could I add a second converter behind the tubes?
gregpphoto.com (external link)
racketman
Gallery: 20 photos
Mar 07, 2009 14:51 |  #2
get a trinocular microscope with dslr adaptor - you know you want it!
Toby
gregpphoto
Mar 07, 2009 14:56 |  #3
racketman wrote in post #7475153 (external link)
Yes I do!! But that's $$ and a lot of intelligence that I may not possess. I've been looking around a lot of microscopy websites, and it is intense. All kinds of math-like stuff and lighting techniques. Bright field, dark field, diffusion, etc. In time, Racketman, in time.
LordV
Mar 07, 2009 15:06 |  #4
Think the most extreme setup I have seen was one with about 500mm of extension tube and I think an enlarger lens on the end giving over 10:1 magnification- it was mounted vertically so did a good impression of being a microscope.
Brian V.
Macro Hints and tips
gregpphoto
Mar 07, 2009 17:42 |  #5
500mm ext. tube?? They make em that big?
racketman
Gallery: 20 photos
Mar 07, 2009 17:54 |  #6
gregpphoto wrote in post #7475929 (external link)
just buy several sets and join them together - or make your own.
Toby
gregpphoto
Mar 07, 2009 18:42 |  #7
Would either of these two setups potentially work? Except I forgot some rings to get the bellows onto the front of the 70-200 in the top one.
IMAGE: http://farm4.static.flickr.com/3599/3336010267_6413533483_o.jpg
LordV
Mar 08, 2009 01:26 |  #8
No this was a DIY setup using I think an aluminium pipe
Brian V.
LordV
Mar 08, 2009 01:30 |  #9
gregpphoto wrote in post #7476231 (external link)
Not sure what #1 would do.
More normal to place any extensions (ext tubes or bellows at the camera end). Think with this form of extreme macro it's a case of suck it and see- Suspect you are going to run into very close focusing problems plus attendant lighting problems.
Coppatop85
Mar 08, 2009 14:08 |  #10
How does the 1.4x effect the macro magnification?
5D3, lenses, tripod, and a flash.
Wobsite: www.coppatopphotos.com (external link)
gregpphoto
Mar 08, 2009 14:23 |  #11
Coppatop85 wrote in post #7480569 (external link)
Wouldn't it magnify the initial lens by 1.4? Thereby giving you increased magnification?
2,332 views & 0 likes for this thread, 4 members have posted to it.
1601 guests, 139 members online
