Thread started 07 Mar 2009 (Saturday) 20:15
problem going from dual to single monitor with Photoshop on XP
Toeslider
Mar 07, 2009 20:15 |  #1
I can't figure this out, never happened before...
Normally I use my laptop with an external monitor and extend my desktop across both monitors. When I take the laptop on the road I disable the external monitor output and everything works like normal, appearing on the laptop screen.
But this time I went out of town, took some pictures and wanted to edit them on the laptop. The problem I am having is that there are certain menus that I apparently had on the external monitor the last time I used them, and they won't show up on the laptop, even though the external monitor output is disabled.
For instance, I can open up Photoshop fine, but when I go to sharpen an image the sharpen dialog box opens but I can't see it, like it is being displayed on the other monitor, which isn't there anymore. When this happens the only way I can get out of Photoshop is Ctrl-Alt-Del, because it is waiting for a response in the dialog box before it will let me do anything else, including closing the image.
Same thing happens in my Sigma software. The settings adjustment button doesn't do anything because it appears to be opening it on the missing screen as well.
Anyone have a workaround for this? I have tried all the monitor settings and nothing seems to change it. It doesn't matter if you disable the second output or not, it still does it. I have also rebooted several times now and it doesn't seem to make a difference.
Canon XTi, 18-55mm kit IS and non, 10-22mm, 28mm 2.8, 50mm 1.8, 580EX
Sigma SD14, 18-125mm DG, 20-40mm f/2.8 EX
Bobster
Mar 07, 2009 20:19 |  #2
i take it you've saved your workspace in photoshop? if not do so now - windows>workspace>save workspace.., and then>
windows>workspace>default
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
DIY Monitor Hood (external link) | Gear | Tweet (external link) | Insta (external link) | FoCal 2 (external link)| Ultimate RAW Editor (external link)
Toeslider
Mar 07, 2009 20:25 |  #3
I guess I should have mentioned I'm still working with Photoshop 6.0...
Bobster
Mar 07, 2009 21:42 |  #4
Window>Reset Palette Positions (bottom of the menu)
Toeslider
Mar 07, 2009 21:54 |  #5
Bobster wrote in post #7477207 (external link)
I tried that after your first suggestion, didn't make a difference. Thanks for the help though.
I think I'm just going to have to wait until I can reconnect a second monitor and move the palettes back to the main screen.
butangviber
Mar 07, 2009 22:56 |  #6
when you move your mouse to the edge of the laptops screen, does the mouse dissapear? or does it stay at the edge of the screen. I only ask because the computer might think that the extended monitor is still there. You can hit Fn + F2 (i think thats it) and it will switch your monitors back to the default.
Jed - My Flickr (external link)
40D l 18-55 l 75-300 l 50 1.8 II
Toeslider
Mar 07, 2009 23:22 |  #7
butangviber wrote in post #7477660 (external link)
It stays at the edge.
unrlmth
Mar 07, 2009 23:29 |  #8
If you don't mid deleting/moving your preferences file. It should reset everything back to normal. You can always move it back when you get home.
Do you have a Mac or PC? I know how to do it in OSX, but I'm not sure about windows.
Toeslider
Mar 08, 2009 09:57 |  #9
unrlmth wrote in post #7477821 (external link)
Thanks! That worked for Photoshop, but for some reason my Sigma software doesn't work the same way. Oh well.
1,179 views & 0 likes for this thread
Latest registered member is Raiony
883 guests, 256 members online
