PaintballPhotography.com wrote in post #7480022
I am currently using a 1D Mark III to shoot sporting events. At present I use only Compact Flash cards. I am considering using both a CF card and a SD Memory Card of equal sizes and have the camera write simultaneously to both cards as a back up.I assume this is a good idea....Will this slow down the write speed of the camera because now it has to simultaneously write to both cards? I have had a history of problems with Lexar cards in the past.I assume there would be no problems with this set upThanks Writing to both will not slow down the camera at all, but it may slow the buffer offload. As long as you don't shoot 30 RAW images in 3 secs you should be fine. If lexar cards are bad for you, try getting the pro models, or switch over to sandisk extreme iii. Backups are generally pointless, the chance of card failure with properly maintained cards is nearly nothing, and even when there is failure you can generally recover a good deal of it.
