Thread started 13 Mar 2009 (Friday) 13:57
24-105 vs. 24-70???
ngrohosky
Mar 13, 2009 13:57 |  #1
for portraiture, weddings, events... what do you think?
thankss :D
timnosenzo
Mar 13, 2009 13:58 |  #2
ngrohosky wrote in post #7517150 (external link)
24-70
yuribox
Mar 13, 2009 14:01 |  #3
Me too. +1
1Ds IR, 5DIII, 1DIII, 17-40, 24-105, 70-200, TS-E24, 40, 50, 85, 100, MP-E65
ngrohosky
Mar 13, 2009 14:08 |  #4
any specific reason? they're both supposed to be amazing quality.. however the 24-70 goes down to 2.8. is that why that is the "better" lens for these cases?
yuribox
Mar 13, 2009 14:13 |  #5
IS will make image stablize about two stops as far as I know. I just think that 2.8 would come in handy for DOF if you need it. The negative side would be that you need wald little bit more. ^^
yuribox
Mar 13, 2009 14:14 |  #6
wald=walk. Sorry. ^^
Grentz
Mar 13, 2009 14:15 |  #7
IS is better for low light static objects
Faster f-stop is better for low light moving objects.
The f2.8 also helps you get a bit more DOF.
Search.TechIslands.com (external link) - Photography Shopping Search Engine
www.TechIslands.com (external link) - News and Reviews
My Gear List - 60D
KayakPhotos
Gallery: 179 photos
Mar 13, 2009 14:17 as a reply to  @ yuribox's post |  #8
Are you shooting full frame or crop? Either way, 24-70 is probably the way to go. f/2.8 will give you more speed when you need it in low light plus a more shallow depth of field. I've seen some good wedding shots taken with the 24-105 though...
Just a thought from Daniel
Gear
Papa ­ Carlo
Mar 13, 2009 14:17 |  #9
thankss :D
So for portraiture or wedding ?
For portraits 24-105 is better, for weddings 24-70.
timnosenzo
Mar 13, 2009 14:17 |  #10
For wedding/events/etc, where you will be taking pictures of people in potentially challenging lighting situations, you're better off with a faster lens than a lens with IS. In situations like that, I use primes, and I use a 24-105 as a walk-around zoom, but if I was going to use a zoom lens at a wedding, I would want the fastest lens possible.
ed ­ rader
"I am not the final word"
Mar 13, 2009 14:23 |  #11
ngrohosky wrote in post #7517208 (external link)
it also has better bokeh. the 24-105L also shows more distortion on a FF camera, something you hear more about these days since more people own FF cameras and the 24-105L is bundled with the 5d II.
when you ask a lens question you should always state which camera you are using because it can make a huge difference in performance.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
cdifoto
Don't get pissy with me
Mar 13, 2009 14:29 |  #12
timnosenzo wrote in post #7517264 (external link)
That's not an absolute. I'm wide open pretty much only during the ceremony. When my f/2.8 zoom is good enough, the f/4 with IS would be too.
The rest of the time, flash can be used and we all know that flash stops action.
The primary reason I have the 24-70 is that the 24-105 was backordered when I was buying and then the flare recall came about. If I was trying to decide today, I'd probably be pulling my hair out.
ngrohosky
Mar 13, 2009 14:40 |  #13
im workin with the 5d, and only have the 50mm 1.8, and also 50mm in 1.4. (one i bought, and the other given to me).
mbellot
"My dog ate my title"
Mar 13, 2009 14:40 |  #14
cdifoto wrote in post #7517328 (external link)
Its called "serendipity", just sit back and enjoy it. ;)
ngrohosky
Mar 13, 2009 14:43 |  #15
the only thing i worry about is that i will need the extra range that the 24-105 gives... but i guess it comes down to more range, or larger aperture.... ughh!! i AM pulling my hair out.
6,342 views & 0 likes for this thread, 36 members have posted to it.
24-105 vs. 24-70???
697 guests, 125 members online
