Thread started 14 Mar 2009 (Saturday) 08:09
How much is too much?
sancho1983
Mar 14, 2009 08:09 |  #1
How much sharpening is too much?
I've sharpened this to about the level i think looks ok, is it too much?
I used USM, some people i've read use Smart Sharpen, is there benefits of either?
IMAGE: http://i635.photobucket.com/albums/uu79/sancho_1983/IMG_5301.jpg
I also desaturated the background to help the flower stand out, forgot to go around and tidy the edges up, then flattened and saved as a Jpeg, so it's not great around the edges of the flower :oops:
Instagram (external link)
Https://bgsweddings.co​.uk (external link)
freebird
Mar 14, 2009 10:11 |  #2
Hi Sancho,
I think that sharpened image @ that size looks ok on my laptop.
One feature in photoshop that often overlooked is the "Fade" effect that one can apply to effects . It has to be done immediately after you apply the effect.
Its under the Edit tab........Fade.
It works nicely especially for sharpening if globally applied. You get a regular photoshop size window to view the adjustments instead of the small USM window to preview with. It's worth checking out for sure
sancho1983
Mar 14, 2009 11:38 |  #3
Thanks,
So you would over-sharpen if anything, and then play around with the fade until it looked good?
Zazoh
Mar 14, 2009 16:31 |  #4
Nah, looks good, for a flower. ;-)a
A Camera - A Lens -- Gear Doesn't Matter
Peano
Mar 14, 2009 16:36 |  #5
sancho1983 wrote in post #7522253 (external link)
Thanks,
No, that's not a good idea. Oversharpening creates artifacts and noise. If you fade that, you still have artifacts and noise, just less than at 100%. When you sharpen correctly, it doesn't create a mess that needs cleaning up.
Peano
RadiantPics.com (external link)
sancho1983
Mar 14, 2009 17:02 |  #6
So do you always start with 150%, 0.3 pixels radius, threshold 0?
Should i create a new layer and sharpen that?
Peano
Mar 14, 2009 17:38 |  #7
sancho1983 wrote in post #7523639 (external link)
No, I start by looking at the image to see what it needs, and then I experiment. Having sharpened quite a few images, I don't have to experiment long. But I don't follow any formulas.
Yes, and I would also recommend using a layer mask on that new layer.
Peano
Bobster
Mar 14, 2009 18:57 |  #8
when posting for the web?
resize then
Sharpen>Sharpen
i then fade the sharpen to 60%
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
freebird
Mar 14, 2009 19:00 |  #9
Each image will be different. Some lens stopped down to F8 need little if any sharpening. I prefer selective sharpening personally.
Portrait usually doesnt take much sharpening, I will look @ the eyes and adjust some if needed. Hair wont sharpen well.
As peano said I would not go heavy handed on sharpening to back it off later. A good example of the fade command sharp would be a landscape scene. In a full window you can see you whole sharp applied to the whole image. Foilage and trees can oversharpen very easily, especially if you have people in the scene too and try to sharpen the whole image.
sancho1983
Mar 15, 2009 12:16 |  #10
Forgive my ignorance, but how do i selectively sharpen? create a new layer, sharpen the entire image then 'paint' back the bits i don't want sharpened?
Thanks all
S.Horton
Mar 15, 2009 12:38 |  #11
sancho1983 wrote in post #7527556 (external link)
Thanks all
If you're talking about using a mask, yes, that will work.
Sam - TF Says Ishmael
:cool:
Peano
Mar 15, 2009 12:42 |  #12
That's one way to selectively sharpen. Another (which can be combined with what you describe above) is to use an edge mask. I use an edge mask for practically all sharpening. See the discussion here (external link) under "Capture Sharpening."
Peano
sancho1983
Mar 15, 2009 12:44 |  #13
S.Horton wrote in post #7527640 (external link)
Yeah, i think so, my problem is i've taught myself how to use PhotoShop in an odd way, so i'm not entirely sure the best way to go about doing things, just muddle through :)
When i 'colour pop' something i create a new hue/saturation layer, take out the saturation, then select the pen tool and brush the colour back into what i want to be coloured. That's a mask right?
I presumed that's what i would do to selectively sharpen something, but instead of creating a new hue/saturation layer i would create a new 'sharp all over' layer
Tom ­ Koidhis
Mar 15, 2009 15:52 |  #14
Ever seen Marc Adamus' sharpening technique? Resize the image to about 1.6 the res you want for web, then apply the "sharpen" filter (seriously). Then create a duplicate layer and apply the filter again to the new layer, once or even twice. It will look horribly over sharpened and noisy in most cases. Then just re-size it to the size you want, and from there you can adjust the opacity of the top layer if it's still over sharpened or mask out areas that are too sharp.
What the resizing does is tricks photoshop into applying an ultra-fine USM, but the technique is variable depending on the photo content.
5D MkII gripped, 50D | 50 f/1.4, Tokina 11-16 f/2.8, 24-105 f/4L, 70-200 f/2.8L | TC-80N3 | Lee Filters | Gitzo GT2531, Gitzo off centre
freebird
Mar 16, 2009 12:37 |  #15
Thanks all
Its just a basic selection. I like to use "quick mask" with a soft brush to make my selection. The tool is near the bottom of tools pallet on CS2. Once you make your selection you have to confirm your selection with the little box right next to it, and you will see the marching ants.
I use it alot ......for eyes on portrait, and also race cars so I dont have to sharpen asphalt, it looks terrible sharpened, about as bad as if you were to sharpen clouds.
Hope that makes sense, I confuse myself even lol:D
2,685 views & 0 likes for this thread, 9 members have posted to it.
1065 guests, 104 members online
