Hi all,
I was wondering whether it still is necessary to upres a processed image for printing in large format, say 24"X 36" or even larger.
The reason I am not sure anymore is that I had a fairly long talk with a Canon employee, who was operating a few Canon large format printers at an exhibition. and who said that the interpolation used by the actual printers is much better than you can achieve by doing it yourself, bicubic or otherwise, even more so because the printer has in-built software optimized specifically for that printer to do so. IOW, just upload your standard maximum size processed image files, same pixel size as the camera provides, and the printer takes care of any uprezzing required for the picture size you want it to print.
The printers demonstrated were the Canon IPF 6100, and IPF 9100 (impressive pieces of machinery for sure, wish I could afford one, either one
So, I would appreciate it if you would explain what your take is on this, and why?
Thank you very much in advance!
Kind regards, Wim
