Thread started 16 Mar 2009 (Monday) 14:55
Can a camera be prone to flare on its own?
randy.wick
Mar 16, 2009 14:55 |  #1
I recently sold a 40D here on this forum. Today, the buyer wrote me an email saying he was experiencing a "glare" whenever he took a shot with excess sunlight. I'm assuming he means flare.
He was shooting with a 50 1.8, and hasn't sent me pictures of the phenomenon.
Is there any way this is caused by a defect in the camera, and not the lens/filter/compositio​n?
I suggested that he take comparison shots with another SLR using the same lens, composition, and settings, and see if he achieves similar flare. I want to be fair, and if it's a problem he is somehow causing I want to help him figure out how to solve this, but it just doesn't make any sense to me that it would be caused by the camera. I used the camera personally for several months and never had any problem with it.
Thanks in advance.
-Randy
equip.
tonylong
...winded
Gallery: 60 photos
Mar 16, 2009 15:19 |  #2
Well, he says he was shooting "with excess sunlight", which presumably means that sunlight was directly striking the surface of the lens. This causes flare, which would be made worse if he was using a UV filter. It can be helped with a lens hood. But it is not a camera defect, just the way the lens handles the light.
Tony
Lyndön
Mar 16, 2009 15:34 |  #3
Hmmm, I've always heard of "lens flare" but never "body flare". Example photos would help greatly to diagnose what is going on. Good Luck.
egordon99
Mar 16, 2009 15:41 as a reply to  @ Lyndön's post |  #4
What body was he using before? I'm 99.99999999999999901% sure the problem has NOTHING to do with the camera, and everything to do with the lens and/or the shooting conditions.
egordon99
Mar 16, 2009 15:41 as a reply to  @ egordon99's post |  #5
When I think body flare, I think "flair" as in Jennifer Aniston and her flair in Office Space :lol:
fdw
Mar 16, 2009 15:44 |  #6
The body itself cannot create flare. It may be the sunlight directly hitting the front lens element and/or filter. It may also be a reflection generated by light bouncing off the sensor glass to the rear lens element then back to the sensor. Either way it is not a "defect" in the camera.
Dennis
www.denniswalton.zenfo​lio.com (external link)
EOS 5D Mark II and Mark III, 16-35 f2.8 L II USM , 24-105 f/3.5-4.5 L II USM , 70-200 f4.0 L USM plus 1.4x
egordon99
Mar 16, 2009 15:44 as a reply to  @ Lyndön's post |  #7
https://photography-on-the.net/forum/showthre​ad.php?t=660853
Sounds like a local sale, call up the guy and talk to him. Did he also buy your 70-200? That lens should handle flare MUCH better than the nifty fifty.
randy.wick
Mar 16, 2009 15:50 |  #8
Yeah, I asked him for examples too. Hopefully he sends them tonight.
He says it's actually not flare, but rather looks more like a reflection on the sensor. I don't quite understand from the description, but hopefully the examples he sends me will help me make sense of it.
-Randy
equip.
randy.wick
Mar 16, 2009 15:51 |  #9
egordon99 wrote in post #7535889 (external link)
Was local-- we'll meet up tomorrow, but I wanted to make sure my understanding was correct before meeting up with him.
Funny, I asked another friend of mine and his answer was "you know who else made their cameras use pieces of flair?" :)
-Randy
equip.
randy.wick
Mar 16, 2009 15:58 |  #10
fdw wrote in post #7535887 (external link)
The sentence I made bold seems to fit his description. Is there a name for this phenomenon, or somehow I might search for example pictures of it?
-Randy
equip.
RDKirk
Adorama says I'm "packed."
Joined May 2004
Mar 16, 2009 19:50 as a reply to  @ randy.wick's post |  #11
Yes, Virginia, there is such a thing as body flare, but there's nothing much you can do about it, and these days one body is probably not any more flare-prone than another.
Set your camera to bulb, remove the lens, and open the shutter. Look into the mirror box. You see a black-painted box with a few mechanical protrubances.
The paint is not a "black body" surface. It reflects maybe 1% of the light that strikes it. Remember that the lens casts a circular beam of light into the mirror box, so there is a lot of stray light bouncing around the mirror box that does not form the image. So when the light entering the camera is really, really bright--such as an image that has the sun in the scene--there is a heck of a lot of light entering the camera, and 1% of a heck of a lot of light can mean quite a bit of flare.
In the old days, some mirror boxes were were more or less effectively "flat black" and reflected more or less light that bounced around the mirror box and eventually struck the film as "flare." Sometimes they had mirror and lens linkages that weren't black at all--fairly shiney metal. Some of the better cameras had mirror box walls that were actually flocked, ribbed, or honeycomb-gridded to reduce reflections and capture stray light. Magazine testers used to comment on the effective blackening of a camera's mirror box.
So, yes, a less effectively blackened mirror box can cause more flare than a more effectively blackened mirror box.
randy.wick
Mar 16, 2009 21:01 |  #12
RDKirk wrote in post #7537534 (external link)
That's an awesome explanation, but doesn't sound like the problem unless the quality of the light-absorbing paint could rapidly deteriorate (i.e., over a period of weeks) in normal apartment conditions.
Unless... could it?
-Randy
equip.
RDKirk
Joined May 2004
Mar 17, 2009 07:47 as a reply to  @ randy.wick's post |  #13
Unless... could it?
It shouldn't. I would not count that as a possibility.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 17, 2009 08:08 |  #14
Should be really easy to test out, put or make a cheap hood on the lens in question and compare shots with and without the hood. If it goes away, I would have to make the assumption that this is purely lens-related.
porschewrx
Mar 17, 2009 09:53 as a reply to  @ TeamSpeed's post |  #15
Did he describe it as round shaped flare spots we normally associate with lens flare Or was it something more like this guy posted?
https://photography-on-the.net …php?p=6923246&p​ostcount=1
Canon 7D, 5DmkIII and a lens or two for each.
2,836 views & 0 likes for this thread, 9 members have posted to it.
1169 guests, 176 members online
