Thread started 16 Mar 2009 (Monday) 16:39
Divide and save a photo into multiple files in PS or other software?
Toeslider
Mar 16, 2009 16:39 |  #1
I'm not sure how to word this to do a search, but what I would like to do is take a scanned image, select several different areas at once, and save them to separate files. I am scanning 35mm film negatives a roll at a time, but I would like to store the images individually and I think I can do it faster/better than the scanner does it if I were to go in after the fact and divide it up. The scanner is set up to recognize individual frames, but more often than not it misses a bunch of them and it is very hard to go in and select the additional areas using the scanner software. It would be easy to take the entire image of what is on the bed of the scanner and divide it up in photoshop, but I don't know how to do that except to select one image, then save it. It would be nice if I could select all the images, then save them all in one step to different files.
If this is possible, can someone point me in the right direction? Thanks!
Canon XTi, 18-55mm kit IS and non, 10-22mm, 28mm 2.8, 50mm 1.8, 580EX
Sigma SD14, 18-125mm DG, 20-40mm f/2.8 EX
earn
Mar 16, 2009 17:00 |  #2
I'm pretty sure that the slice tool in photoshop would do the trick? Although, I have never used it myself. Its used for dividing up an image for websites.
colt
Mar 16, 2009 20:13 |  #3
use the slice tool to "cut" it up however you want, then use save for web and each slice will be a file. If you intend to edit them further, save as gif or png so you don't get jpeg losses and artifacts. if you have < cs3, you can use imageready to do the same thing.
I see dead pixels....
Toeslider
Mar 16, 2009 20:53 |  #4
Sweet, that looks like it will work. There are a lot of settings to mess around with, but it seems to do what I'm looking for.
960 views & 0 likes for this thread
Latest registered member is Bcyphers
1302 guests, 356 members online
