Until recently I had Hitech filters, which I bought originally because I read that they were optically the same as Lee filters. I had the 1, 2 and 3-stop 85mm resin filters in hard and soft edge gradients, plus a 5-stop and a 10-stop standard ND filter.
When used individually the (gradient) ND filters were fine, but if stacking two or three there was a significant magenta colour cast. The 5-stop and 10-stop standard ND filters introduced a MASSIVE magenta colour cast that annoyed me to the extent that I sold the whole lot and moved over to the Lee 100mm resin filter system, which I should have bought to start with.
When compared with the results from my friend's Lee set-up used at the same times/locations as my Hitech filters, I found that the Lee filters were significantly better than the Hitech filters.
My advice would be to go with the Hitech filters if you are on a tight budget, but ultimately the Lee system is the best, which is of course reflected in the price.
Mike
