Thread started 06 Apr 2005 (Wednesday) 15:41
Spare G6 battery advice wanted.
PRJ
Apr 06, 2005 15:41 |  #1
Hello all, I want to get a spare battery for my G6, and have seen one on the Euro Batteries website for just £14.54 inc postage. It is a 1500mah high capacity, and i wondered if anyone has bought one, or could recommend them. Also does it make any difference because the Canon battery that came with the camera is 1390mah. I have read that it is important to get the right battery, or else it could damage the camera. Any help and advice would be appreciated.
Regards, Phil.
Romy
Joined Jun 2004
Apr 06, 2005 16:26 |  #2
I bought a spare battery in Jessops - their own make. It was half the price of a Canon battery and I've not noticed any difference in performance.
am_pitbull_terrier
Apr 06, 2005 16:46 as a reply to  @ Romy's post |  #3
There is already a thread started on this. I checked out the link for the ebay one... Ended up buying some there myself. :)
https://photography-on-the.net/forum/showthre​ad.php?t=64947
Powershot G3
LA-DC58B Lens Adaptor
Spot Filter 58mm
Diffusion Filter 58mm
SkyLight Filter 58 mm
SuperWide Lens
Rebel XT (black), 18-55mm, 24-70mm 2.8, 70-300mm /Lens Hood, 50mm 1.8
Opteka Grip
Radio Slave Trigger
Stroboframe Flash Bracket
580EX Flash & Canon Off Shoe Cord 2
Lumiquest On-Camera Softbox
And of course a POTN camera strap :)
PRJ
Apr 07, 2005 13:58 as a reply to  @ am_pitbull_terrier's post |  #4
Thank's for the replies, checked-out previous threads on subject, but only refers to e-bay and does'nt answer my questions relating to euro batteries etc. Anyone else out there who can?
Phil.
MegaZone23
1 post
Apr 11, 2005 08:23 |  #5
PRJ, it's really hard to say anything about the Euro Battery 1500mAh batt, because it doesn't really give a lot of info beyond that. One thing you want to do is contact them to find out whether or not they are using Japanese cells to build the batteries. A lot of these 3rd party batteries use cheaper Chinese cells, which don't last nearly as long even though they are rated the same.
I can recommend SterlingTek's 1800 mAh batteries. They are made from Japanese cells, and Mike is very quick to respond to any queries. If you order from their site, the batteries are US$12 each.
PRJ
Apr 11, 2005 16:06 as a reply to  @ MegaZone23's post |  #6
Thank's for the info. is it ok to use the 1800 mah one though, (as i mentioned initially the original canon one being 1390 mah) e.g. would the step-up in mah do any damage to the camera? .....just want to make sure...and be safe.
Regards, Phil.
kring
Apr 13, 2005 11:40 as a reply to  @ PRJ's post |  #7
No it won't damage it. mAh is the amount of power that can be stored in the battary, technically the higher you go the longer it will last. It is not sending more power. Same for rechargabe AA batteries the 2500mAh last longer then the 1600mAh but they both have the same 1.25Volts.
As MegaZone23 stated, you need to make sure your getting good cells, the mAh rating is not the definitive judgement, I tried 2 different off-brand batteries (sunpack & lex or lux-something) for my Canon G6 and both were garbage. They were rated higher then the BP511-A yet both lasted a fraction of specifications and both ran out of juice within 2 weeks even if they were not in the camera. They seem to always be dead. Charing the battary I noticed both tend to be warm, while Canon's was room temp. the original OEM Canon battery seems to have an endless supply. I just bit the bullet and went with a Canon BP511-A.
But if you can located from other users good battaries go for it because the Canon is about $40-50.
Canon 30D
Canon Rebel XT Silver
Canon EF 50mm f/1.4 USM
Canon EF-S 17-85mm IS USM (Hoya Pro1 UV & Lens Hood)
Canon 430EX Flash (Sto Fen Omni-Bounce)
PRJ
Apr 13, 2005 16:04 as a reply to  @ kring's post |  #8
Thanks for explaining Kring, i understand what you are saying.
Best regards, Phil.
2,289 views & 0 likes for this thread, 5 members have posted to it.
2284 guests, 93 members online
