http://www.flickr.com/photos/thepumpkinmen/![]()
Opinions? Reviews?
motoroller Senior Member 474 posts Likes: 1 Joined Jul 2008 Location: Near London More info | Mar 20, 2009 15:21 | #1 http://www.flickr.com/photos/thepumpkinmen/ Current: 5d III | 1Ds3 | 5d II gripped | 40d | 17-40L | 24-105L | 50mm f/1.4 | 100 f/2 | 70-200L f/2.8 | 430EX |
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Mar 20, 2009 15:36 | #2 That is an entire flickr portfolo. Too many pictures to critique. If you want critique on a particular photo please post the photo in question here. .
Mar 20, 2009 15:44 | #3 Ok - sorry about that Current: 5d III | 1Ds3 | 5d II gripped | 40d | 17-40L | 24-105L | 50mm f/1.4 | 100 f/2 | 70-200L f/2.8 | 430EX |
aram535 Goldmember 1,915 posts Joined Sep 2007 Location: Long Island, NY More info | Mar 20, 2009 16:15 | #4 Since you're new -- to get the best feedback you should actually have the images appear in the forum. Read the sticky on top on embedding. Gear List * www.tranquilphotos.com
LeuceDeuce Goldmember 2,362 posts Joined Oct 2007 Location: Vancouver BC, Canada More info | Mansfield College needs to be leveled, and correct the keystoning. There's also a weird bright halo around the building on the right. The building on the right is also over exposed. my website: Light & Shadow
Mar 21, 2009 11:23 | #6 aram535 wrote in post #7564477 Since you're new -- to get the best feedback you should actually have the images appear in the forum. Read the sticky on top on embedding. In an image, you really need to have a "look at me" portion. What are you trying to show to the user. I don't see that in the first two. Your soccer shot is pretty good, although if you had gotten down a little further and shot up and across at them it would have been a stronger image. I hope that helps. Thanks for the feedback. The first two are really just documentaries of the college grounds and main buildings - for example, as shots for newspaper articles on those colleges. Current: 5d III | 1Ds3 | 5d II gripped | 40d | 17-40L | 24-105L | 50mm f/1.4 | 100 f/2 | 70-200L f/2.8 | 430EX |
Mar 21, 2009 11:24 | #7 LeuceDeuce wrote in post #7564685 Mansfield College needs to be leveled, and correct the keystoning. There's also a weird bright halo around the building on the right. The building on the right is also over exposed. Keble College also suffers from a tilted horizon. The ungrounded tree branches on either side also tend to detract from the visuals. Walk a few steps forward and you'll get a better angle to see more of the college while eliminating the distracting elements. Football Tackle was shot too low (cut off the head of the player in back when there was ample room to point up), and too much negative space on the right. Thanks! The halo was from my initial ideas of HDR - I didn't realise there was software to automatically merge exposures so I did that manually, hence the halo. Point noted Current: 5d III | 1Ds3 | 5d II gripped | 40d | 17-40L | 24-105L | 50mm f/1.4 | 100 f/2 | 70-200L f/2.8 | 430EX |
| Latest registered member is semonsters 1611 guests, 142 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
