Hello and Merry Christmas to all,
I bought myself a 420EX flash for my G2 and have been experimenting with it. I haven't been able to play with it outside in the daylight, but have been playing with it a LOT in the house at night after work.
First, let me say if you don't have this flash... Get it! Shots inside the house bouncing the flash off the ceiling are the most realistic shots I have seen where a flash was used.
Okay, on to my question. Correct me if I am wrong, but when in Auto and (P)rogram, the flash fires as the main source of illumination and thus you end up with more of that nasty white flash colored light (unless you are bouncing). In Av and Tv the flash is supposed to fire in "fill flash mode."
What I am noticing is inside the house, P shots with the flash turned off expose at 1/10sec F2.0. Now if I take an Av shot dialed in at F2 with the flash on, I get 1/60sec at F2. That shot looks identical to a P shot with the flash on which exposes at 1/60sec at F2.
I can't tell a difference between what I would consider main illuminination and fill flash.
Just as an experiment, I placed the camera in Tv with 1/10sec (it picked f2.0). That shot I could tell was in fill flash mode. Of course anything moving blurred, but that is to be expected at 1/10sec.
Now with all my babble out of the way, anyone know why I cannot tell a difference between the Av and P with the flash? The only thing I can assume is the slowest sync speed of the camera (I think) is 1/60sec so in Av it is picked 1/60 with the f2.0 and thus the flash thinks it needs more power to "properly" expose the film.
Does this sound like what is happening? I am right about the Tv and Av fireing in fill flash mode, right?
Thanks all,
Michael
