hi,
I have many q? about Photographer Assistant and wanna help plz
1- who is Photographer Assistant ?
2- what is his job and what are works he does ?
3- what is skills he should have ?
4- as a Photographer do u need one ? and why ?
thanx
Aydarous Member 35 posts Joined Feb 2009 More info | Mar 24, 2009 02:30 | #1 hi,
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Mar 24, 2009 04:22 | #2 I recently hired an assistant. Their job is to do anything it takes to help me take great photos. This means helping pack and unpack gear, carry things, watch for details I miss, drive sometimes when I don't want to, that sort of thing. They're to make my life easier. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Mar 24, 2009 09:06 | #3 thanx Tim
MJPhotos24 Cream of the Crop 5,619 posts Likes: 4 Joined Nov 2005 Location: Attica, NY / Parrish, FL More info | Mar 24, 2009 11:09 | #4 I've only used two assistants before and got kinda a bad taste, one was good and one was definitely not so I stopped using them all together and did everything on my own. Doing it solo can wear on you pretty quick so currently looking for one to do part time work this year - basically as Tim said they're there to make life easier. Main use will be for T&I so they'll be helping setting up the equipment, getting the kids organized, collecting envelopes and getting the kids to choose a pose, then helping set up the pose before moving on to the next kid, looking to see if I missed anything, etc. After the shoot will be helping sort and mark off orders - count and record what was pulled in, etc. Freelance Photographer & Co-founder of Four Seam Images
sfaust Goldmember 2,306 posts Likes: 10 Joined Nov 2006 More info | Mar 24, 2009 19:35 | #5 I use assistants on most of my assignments, and have two I work with regularly, and a few others that I use on occasion. For the most part, I typically only have one assistant working with me at a time, but have had up to 4 on larger projects along with the stylists, MUA's, models, etc. Stephen
PeaceFire Goldmember 2,281 posts Likes: 1 Joined Feb 2009 Location: Glendale, AZ - Chico, CA - Duluth, MN More info | Mar 24, 2009 21:18 | #6 My assistant is more of a partner, really. She has her own company, I have mine, and to get more work we hire each other. Only I'm better at actually getting clients booked so I've hired her, like, a dozen times and she has yet to need me. Probably the way it'll be for a while. Anyway, her job is to help me get full coverage. At a wedding I can't be getting the bride walking down the aisle AND get the reaction of the groom when he sees her for the first time. My assistant's job is to stay on the groom so I don't have to worry about that.
PhotosGuy Cream of the Crop, R.I.P. More info | Mar 24, 2009 21:47 | #7 Because you have a descriptive title, you can look at the "Similar Threads" links at the bottom-left of this page for more info. FrankC - 20D, RAW, Manual everything...
KarlJohnston Cream of the Crop 9,334 posts Likes: 5 Joined Jul 2008 More info | Mar 24, 2009 22:32 | #8 Permanent banGot good responses from some of the best photographers on here, wow, can't ask for much better than that. Adventurous Photographer, Writer
tim, MJPhotos24, and sfaust ----> Thanx a lot, it's really very useful.
jblaschke Goldmember More info | I'm my wife's assistant, so I'm probably not typical. I serve as a second shooter when needed. I research equipment purchases and tech stuff. I carry equipment and handle set-up for a shoot. I scout locations. I recruit models for projects. I make sure there are refreshments available on a shoot. I hold the reflector (pretty good at that) and act as a second set of eyes. I'm a troubleshooter if something's not working for a shot. I'm a test model. I PP my own work, but she PPs everything she shoots--and sometimes mine. I'm a sounding board for ideas. Canon 7D | Canon 50D IR modified | Canon EF 70-200mm 2.8 IS L | Canon FD 500mm 8.0 Reflex | Canon EF 85mm 1.8 | Canon EF 50mm 1.8 mk I | Canon EF-S 10-22mm | Tamron 28-75mm f/2.8 | Meade 645 (762mm f/5)
EveryMilesAMemory Goldmember More info | Mar 26, 2009 16:11 | #11 jblaschke wrote in post #7604008 I'm also probably the only person who'd tolerate being called "Lensboy," so there's that, too. ![]() That's funny because my wife is my assistant, yet I'm still called "Lensboy"...LOL And here I thought I was the only one Pat Bonish
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Mar 26, 2009 17:18 | #12 Since my assistant does a lot of lighting work with me, I sometimes call her Phil. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
-g- Horribly disfigured but learning to cope 12,520 posts Likes: 32 Joined Dec 2007 More info | EveryMilesAMemory wrote in post #7605005 That's funny because my wife is my assistant, yet I'm still called "Lensboy jblaschke wrote in post #7604008 I'm also probably the only person who'd tolerate being called "Lensboy," so there's that, too. ![]() Beat being called "Lensbaby".
| Latest registered member is Frankie Frankenberry 1718 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
