Does anyone make an Arca-Swiss compatible plate for mounting a flash? Basically a normal QR plate with a cold shoe on it. Or better yet, a source of a cheap Arca-Swiss QR plates and a good cold shoe to mount on top?
adam8080 Goldmember 2,280 posts Likes: 1 Joined Jul 2007 Location: Huntsville, Alabama More info | Mar 26, 2009 15:41 | #1 Does anyone make an Arca-Swiss compatible plate for mounting a flash? Basically a normal QR plate with a cold shoe on it. Or better yet, a source of a cheap Arca-Swiss QR plates and a good cold shoe to mount on top? Huntsville Real Estate Photography
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Mar 26, 2009 15:45 | #2 I believe RRS makes on for Nikon flashes, but I havent seen anything for Canon ones. However you could get a universal arca-swiss plate and screw it into the bottom of the little stand feet that come with the flash and then use that to mount it. Does that make sense? [Gear List | Flickr
adam8080 THREAD STARTER Goldmember 2,280 posts Likes: 1 Joined Jul 2007 Location: Huntsville, Alabama More info | Mar 26, 2009 15:48 | #3 ben_r_ wrote in post #7604853 I believe RRS makes on for Nikon flashes, but I havent seen anything for Canon ones. However you could get a universal arca-swiss plate and screw it into the bottom of the little stand feet that come with the flash and then use that to mount it. Does that make sense? Yes, but I would like something a little more sturdy to use than the piece of plastic that comes with the Canon flashes. Huntsville Real Estate Photography
adam8080 THREAD STARTER Goldmember 2,280 posts Likes: 1 Joined Jul 2007 Location: Huntsville, Alabama More info | Mar 26, 2009 15:51 | #4 Thanks I just found one: http://reallyrightstuff.com …esc.asp?ic=FA-CS3&eq=&Tp= Huntsville Real Estate Photography
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Mar 26, 2009 15:53 | #5 Oh wow! Good find! Ive never noticed that piece before! Well there you go, and being that its from RRS its def going to be of the finest quality!
[Gear List | Flickr
| Latest registered member is semonsters 1708 guests, 141 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
