My RAW workflow using ACR 4.6 consists of the following:
1. My default camera profile that I like is Camera Portrait for my D700
2. Correct WB.
3. Adjust the exposure slider to set the whitepoint/general brightness of the image. If the image would be too dark in order to recover any clipped highlights I adjust the slider to get the brightness I want then recover the clipped highlights using the recovery slider.
4. Adjust the recovery slider if there are still some clipped highlights after adjusting the exposure slider. I never take this slider above 30.
5. Adjust the black point until I see a minor amount of clipping in areas where detail is important, then back down a notch.
6. Adjust fill light only if required. I don't like to exceed 15 with this slider.
7. Adjust contrast up or down depending on if the above looks a bit flat or a bit too contrasty. Often I leave it at the default of 25 and leave touching up contrast to Curves in PS.
I don't use any of the other sliders on the basic tab.
My confusion is, typically when I click "auto" exposure isn't touched but brightness is. Contrast is also often jacked way up and the image looks horrible. Does anyone know what logic Adobe uses for the "auto" mode in ACR 4.6 (and is 5.x any better)?
Also, can anyone explain what I'm missing by not using the brightness slider? Am I doing anything wrong with the above workflow?
