Thread started 10 Apr 2005 (Sunday) 07:44
Help with Custom white balance for infared
Pamela107
Joined Nov 2003
Apr 10, 2005 07:44 |  #1
I have been trying infared photos, but there not turning out with my G3
I think I m not setting Custom White balance correctly , or I dont have the settings correct on my camera.
The Booklet that I have for the camera isnt very clear on how to set custom white balance.
(I do have Photoshop 6.0 and have the info for channel mixing)
Thank you
Pamela
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
www.exposedimages.net (external link)
Don ­ Ellis
Joined Sep 2001
Apr 10, 2005 08:09 |  #2
The Booklet that I have for the camera isnt very clear on how to set custom white balance. (I do have Photoshop 6.0 and have the info for channel mixing)
Thank you
Pamela
For comparison, I shoot RAW, ISO 50, P mode with Auto White Balance on my G1. Then I convert the RAW file to TIF using Custom White Balance (which is simply a matter of clicking the eyedropper on any part of the photo that should be medium to dark gray).
I don't do channel mixing, however, so can't suggest anything.
Cheers,
Don
RAW
Joined Jan 2005
Apr 10, 2005 14:38 as a reply to  @ Don Ellis's post |  #3
As far as I know to set a cutom white balance you have to press the navigational button down once, and the screen that you get should be for the white balance settings. Now, If you want to do a CWB, using the directional pad take it to the C1 and put your lens in front of a blank white paper so it fills the whole area, and without using flash pres set so the camera evaluates White Balance.
Note that not on all settings is CWB available...
This goes for the G6 cause that is the only G series camera I have owned, but I asume that the same things goes for all of them...
Hope this helps...
Regards,
Artan.
Artan
I have my G6s Kenko TC for sale...please PM.
Eos 2oD I EF50mm f/1.4 I 28-135mm f3.5-5.6 IS I 24-70L I 580ex.
PS G6 I 420ex I LA 52/58mm I Hoya HMC polarizer
Kenko KNT-20 2x I Raynox DCR 6600PRO .66x.
I'm lovin' it...:D
dewmuw
Joined Jul 2002
Apr 10, 2005 15:27 |  #4
I've had my best IR results with a G3 when I have set the CWB in the following way:
In TV mode click WB.
Place a piece of white paper in front of the camera (close but not touching)
Choose CWB 1 or 2
Click the * button
Hey presto!
I found trying to set the CBW with the IR filter on or from the actual image you are trying to capture doesn't yield very good results!
Damian Waters
www.drumimages.co.uk (external link)
dewmuw
Joined Jul 2002
Apr 10, 2005 15:28 |  #5
This was taken using the technique described above:
Damian Waters
IainB
Joined Jan 2002
Apr 10, 2005 16:28 as a reply to  @ dewmuw's post |  #6
Is that straight from the camera? My Hoya R72 initially produces a magenta hue.
IainB
"Chi non ha moglie non ha padrone."
ekrunaj
Joined Feb 2004
Apr 10, 2005 21:49 |  #7
What filter are you using and what camera settings are you using? If you could show some examples of the images in question, the rest of us could probably be more able to help you solve your issues and get you out there making images.
dewmuw
Joined Jul 2002
Apr 11, 2005 03:13 |  #8
No it is not straight from the camera. I use a Hoya R72 and get the purple/magenta hue. I then process in PS - and end up with this! I don't have the process handy (I am in work) but I will try and post it when I am home.
Damian Waters
Feihung08
Apr 11, 2005 10:32 as a reply to  @ dewmuw's post |  #9
Hey guys, I don't want to go off subject, but does anyone know of another thread that gives more 'how to' advice on shooting Infared??
THANKS!!
Canon 80D | Tamron 28-75mm | Canon 50mm 1.8 | Canon 430 EX | LensBaby 2.0
Pamela107
Joined Nov 2003
Apr 12, 2005 02:04 as a reply to  @ Feihung08's post |  #10
Thankyou all
Oh gez, I now realize what I didnt do correctly, Im at work and will make the proper changes later. I will show a photo if it turns out.
Pamela
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
2,238 views & 0 likes for this thread, 7 members have posted to it.
2284 guests, 93 members online
