aarbiser wrote in post #7642614
Thanks for the responses.
But for moving subjects IS is not important. I would only use the lens on a monopod. Would the 300 2.8 non IS be better than the 300 f4 IS in terms of image quality or similar. As is would get a much faster shutter speed low light would be easier in the first place wouldnt it?
For fast moving subjects you are right, the IS is of little value and the 2.8 is the best lens (without addressing the possibilitiess of panning mode for IS at least). My experience in "stalking" deer, turkeys, various other large birds and mammals with the 300 f/2.8 is that the IS is probably of more value than the one stop of "speed" gained from 4 to 2.8. With that said, the pop of the subject from the background with the wider 2.8, the creamy bokeh and sharpness of the 2.8 I believe will produce nicer images for you in sports and wildlife assuming you get the shutter speeds you need.
Guess you will have to do like the rest of us and save your pennies for the 300 f/2.8 IS! This lens for me has proven the best validation yet of the advice "glass before body" to get better image quality.
For your budget and needs though, I would still recommend the 300 f/4- you would be very happy with it.
