Thread started 30 Mar 2009 (Monday) 15:02
Which lens 24-70L or 17-55 2.8 ?
jbrown7815
Mar 30, 2009 15:02 |  #1
Ok I have 40D.
I mainly shoot glamour/fashion. Occasional car shoot. Usually will have off-camera lighting. Sometimes studio.
I just started over on equipment, and just bought the 40d, so right now, I have no lenses at all.
Looking to spend around 1k on lens/lenses
My original plan was to buy 24-70 2.8L and stick with just that. As everyone says it's an awesome lens.
What about buying 17-55 2.8 & 50mm 1.4/(or)85mm 1.8
What do y'all think?
~Jesse~
gjl711
"spouting off stupid things"
Mar 30, 2009 15:07 |  #2
I have both the 17-55 and the 24-70. I like both lenses but I prefer the 17-55 on my crop body and the 24-70 on my full frame body. Optically the two lenses are so close as to call it a draw though the 24-70 is a bit warmer color wise than the 17-55.
But if i had to choose between the two, the answer for me is simple, Go for the one with IS. The 17-55 is more versatile because of it's outstanding IS. It is easily hand holdable down into shutter ranges where subject motion blur becomes a real concern.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Wilt
Mar 30, 2009 15:19 |  #3
Your choice between these two lenses should be driven entirely by your range of FL available/needed for the format body that you use -- not by 'better lens', nor driven by the 'I want to buy FF in the future' sentiment.
Some people are better served by a true-wide-to-short tele FL range (17-55mm on APS-C; 28-90mm on FF); others are driven by a 'normal-to-medium-tele FL range (24-70mm on APS-C; 40mm-110mm on FF). Personally I would be best served by a 15-65mm on APS-C (or 24-105mm on FF), but that is my own need for the 'very wide' FL which provides an 84 degree AOV.
jbrown7815
Mar 30, 2009 15:52 |  #4
Thank you both for the good explanation/answers.
If the 17-55 has same IQ as 24-70, why does everyone rave about the 24-70? I guess the 15mm more FL helps.
17-55 is as good as the 24-70 in low light also?
~Jesse~
GorgeShooter
Mar 30, 2009 15:59 |  #5
I currently have the 24-70 and recently sold my 17-55. I prefer the 24-70 because of it's superior image quality, sealed body, and build quality. My 17-55 filled with dust. Although it's somewhat easy to clean, it speaks volumes to the build quality where the 24-70 shines. At times I wish I had IS but don't miss it. I like the simplicity of a non-IS lens. I've ruined many shots on a tripod with IS turned on with my 17-55. The 24-70 is a lot heavier and that is its biggest con IMO. I think the 17-55 is over priced (again IMO).
1DX | 5D MkII (gripped)
16-35 f/2.8L | 24-70 f/2.8L | 24-105 f/4L IS | 70-200 f/4L IS | 100-400 f/4.5-5.6L IS | 24 f/3.5L TS-E | 45 f/2.8 TS-E | 40 f/2.8 Pancake | 15 f/2.8 Fisheye | Tokina 100 f/2.8 Macro | Canon 1.4x TC | 580 EX II | 430 EX II | Manfrotto 055CXPRO4 | Kirk BH-1
:: Smugmug :: (external link) | :: Photography BLOG :: (external link) | :: Workshops and Classes (external link) ::
Wilt
Mar 30, 2009 16:00 |  #6
jbrown7815 wrote in post #7631192 (external link)
'L' fever. Some would say the 'L' has even better color rendition.
The 17-55mm is BETTER than the 24-70mm in low light...it has IS to deal with shakey photographers!
jbrown7815
Mar 30, 2009 16:12 |  #7
GorgeShooter wrote in post #7631230 (external link)
Does having IS on decrease IQ or something?
Wilt wrote in post #7631244 (external link)
Sigh. I don't know what to get. :p
~Jesse~
itmfl
Mar 30, 2009 16:16 as a reply to  @ jbrown7815's post |  #8
i say stick with your original plan and get the 24-70
XTI | G10 | 24-105L | 30 1.4 | 85 1.8 | 430EX II
kansascityshuffle
Mar 30, 2009 16:17 |  #9
jbrown7815 wrote in post #7631317 (external link)
IS will actually CAUSE a vibration on a tripod. hit the switch and shut it off.
JAKE
Sony A7 - SMC M 28/2.8 - FE 35/2 Sonnar -
Contax G 45/2 Planar - Canon FL 135/2.5
toxic
Mar 30, 2009 16:18 |  #10
On some (most?) IS lenses, IS must be turned off when the camera is on a tripod or it'll start freaking out since there's not movement.
Do you prefer wider (17-55) or longer (24-70)? Are your subjects usually static (17) or not (17 or 24)?
If you happen to prefer longer and your subjects are static...24-105 IS.
Wilt
Mar 30, 2009 16:20 |  #11
Imagine the 24-70mm f/2.8L IS...how extra expensive THAT would be -- $400-500 more than it is now!
darosk
Mar 30, 2009 16:24 |  #12
Wilt wrote in post #7631363 (external link)
Probably be hecka heavier too :)
IMO the I'd pick the IS over the L. Also the 17-55 is wider, so +1 for that in my book.
Tumblr (external link) | Facebook (external link) | Youtube (external link)
Gear
Wilt
Mar 30, 2009 16:28 |  #13
jbrown7815 wrote in post #7630873 (external link)
Ok I have 40D.
I just started over on equipment, and just bought the 40d, so right now, I have no lenses at all. Looking to spend around 1k on lens/lenses
My original plan was to buy 24-70 2.8L and stick with just that. As everyone says it's an awesome lens. What about buying 17-55 2.8 & 50mm 1.4/(or)85mm 1.8
For fashion and glamour, I think 24-70mm is a better FL range to have for APS-C. For weddings, 17-55mm is better FL range for APS-C. For walkaround shooting particularly if travelling in Europe, I would opt for the 17-55 because of 'wide' and because it is not as heavy a brick to carry, and for IS.
The 85mm is too long on APS-C...forcing you back too far, where other photographers could step into your FOV and block your shot! Solo work in the studio it would be good, for the increased isolation without concern of blocked shots, if your shooting area is large enough (min. 24' to the subject, for a full length shot!)
[Hyuni]
Mar 30, 2009 16:49 |  #14
Don't mean to be the devil's advocate, but have you thought about primes?
the Canon 35 f/2.0, Sigma 50 f/1.4, Canon 85 f/1.8 could be a good alternative to the zooms you suggested.
Those primes are notorious for great portrait shots.
6D Rokinon 14 f/2.8 l EF 35 ƒ1.4L l EF 135 ƒ2.0L l EF 70-200 ƒ2.8L IS II l YN460 l 580EX II l Flick'd (external link)
kansascityshuffle
Mar 30, 2009 17:18 |  #15
[Hyuni wrote:
='[Hyuni];7631531']Don​'t mean to be the devil's advocate, but have you thought about primes?
Or the 28 1.8 and Sigma 30 1.4 if we are talking about primes! That is an entirely new can of worms...
JAKE
3,094 views & 0 likes for this thread
Latest registered member is countrygirl67
928 guests, 273 members online
