adam8080 wrote in post #7639652
In film, you can't do that because each frame has a physical start and end, but that isn't the case with digital.
OK ... so a digital camera sensor (CCD or CMOS) works by converting light (photon) into electric charge (electrons), just like a solar cell ... but the sensor physically stores the electrons in the area that they were create (pixel area) so that image information is retained in the sensor.
The issue with "overlapping" exposures, is that the charge has to be physically moved OFF the sensor, to be read and converted to digital. By reading the sensor, the image is moved off ... so you can't keep "adding" to that image after it was read .. the sensor is empty once it's been read.
But my Sony FX1 can do right down to 1/4, with all of its glorious and crazy motion blur.
This usually works by simply doing a 1/4 second exposure, and writting it out to several frames. Capture the video into a computer and you'll see that, at 1/4 second shutter speed, blocks of as many as 8 frames together will probably have the same image.
