Do they wear out after a 18 months of use or can you continue using them for many years?
I'm not talking about how many shots per charge, but how many years of recharging before the battery needs to be replaced.
n1as Goldmember 2,330 posts Likes: 25 Joined Oct 2007 Location: Salem, OR More info | Mar 31, 2009 18:39 | #1 Do they wear out after a 18 months of use or can you continue using them for many years? - Keith
jklewer Goldmember 1,292 posts Likes: 1 Joined Jan 2007 Location: 34N 118W More info | Mar 31, 2009 19:31 | #2 Im sure they will last you longer than 18 months. It does depend on how much you are shooting, but you will be fine. Be sure to drain and fill them once in a while as well.
mastertech01 Goldmember 2,098 posts Likes: 5 Joined Jun 2007 Location: LAWTON OKLAHOMA USA More info | Mar 31, 2009 21:13 | #3 I used 1D classic batteries 5 years old plus. It is the same battery. They didnt hold charge well after about 3+. I like old dead 1D batteries though. Ill take as many as I can get. The major diff is the MKII doesnt put the drain on that the classic does, so the life may be longer.
| Latest registered member is semonsters 1505 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
