Thread started 04 Apr 2009 (Saturday) 15:10
adding more zoom
eyesociety
Apr 04, 2009 15:10 |  #1
I have a Canon 40D 17-85 IS + Canon 70-300 1:4-5.6 IS USM lens and want to get more zoom.
Can i get a canon Extension tube or ring that will fit the above equipment.
Cheers.
Eyesociety
Nikon z9 + Nikon Z 24-120mm f4 S Lens + Nikon 500 F5.6 PF Lens
https://www.flickr.com​/photos/186051634@N02/​albums (external link)
bacchanal
Apr 04, 2009 15:15 |  #2
Extension tubes effectively decrease the minimum focus distance and allow you to get closer to an object (for macro type work). You lose the ability to focus at distant objects.
I'm assuming that you want reach and not zoom range.
A teleconverter will multiply the focal length of the lens, effectively increasing the reach. However, they decrease the maximum aperture and generally degrade IQ and focus speed. If you use a teleconverter on the 70-300, you will lose the ability to AF, because your camera can't autofocus at f/8. I'm not sure if the 70-300 is officially supported by the Canon t-cons.
Your best is probably to look into a longer lens, but pretty much anything above 300mm isn't cheap.
eyesociety
Apr 04, 2009 15:23 as a reply to  @ bacchanal's post |  #3
:cry: It does look like i will have to spend some penny's then o well.
Thanks for the reply,
Eyesociety
tkbslc
Apr 04, 2009 15:44 |  #4
You can use a cheaper Kenko 1.4x (1.5x) extension tube, but you will likely be using manual focus and need lots of light for a good shot.
Taylor
EOS Rp | iPhone 11 Pro Max
Madweasel
Apr 04, 2009 15:47 |  #5
Yes, "cheap" and "high image quality" go their separate ways once you're past 300mm!
Mark.
bacchanal
Apr 04, 2009 15:50 |  #6
tkbslc wrote in post #7666916 (external link)
Your talking about teleconverters not extension tubes...there is a big difference. Teleconverters have optics in them, extension tubes do not.
BigAlz1
Apr 04, 2009 18:20 |  #7
bacchanal wrote in post #7666764 (external link)
? HUH ?
No auto focus at F8 on what camera?
Eos 7D, 40D w/70-200L 2.8 IS, 50mm 1.4, Nifty Fifty II, 100MM 2.8 Macro, 18-135mm IS , Sigma 30mm 1.4 , Sigma 18-35 1.8 ART 580ex II
Madweasel
Apr 04, 2009 18:23 |  #8
BigAlz1 wrote in post #7667688 (external link)
? HUH ?
All except the 1D series. The f/8 limitation is when f/8 (or slower) is the MAXIMUM aperture, not just when you choose to set f/8 on an f/5.6 or faster lens.
Mark.
BigAlz1
Apr 04, 2009 18:26 |  #9
Think this is what he ment, so for the new guy this should explain it a bit better.
Most Canon EOS bodies require that the final aperture of the lens be f5.6 or faster in order for autofocus to operate. Since a 1.4x TC cost you 1 stop of aperture and a 2x costs you 2, this means that for a lens to AF with a 1.4x TC it must start out at f4 or faster, and for it to AF with a 2x it must start out at f2.8 or faster.
NeutronBoy
Apr 04, 2009 22:09 |  #10
add the fact that the autofocus is hapenning before the camera moves the lens' aperture blades for the picture. If the starting point is too dim, the body can not focus the image.
Sony A7C, Sony A6000, 5D Mark II, 40D, 350d
Canon 70-200 f2.8 IS II L | Canon 100-400 IS L [COLOR=black]| Canon 24-70 L | Canon 100mm Macro f2.8 | Canon 50 f1.4| Canon 10-22 | Canon MP-E 65 | Rokinon 14mm f2.8 | Sigma 17 - 70 macro
MT-24 & 430 flashes | other junk
PKSmith
Apr 04, 2009 22:26 |  #11
I believe if you are really desperate, you can use teleconverters and just tape the pins so that the body doesn't "see" it. It will focus slowly, but it still may focus. Obviously this isn't anywhere close to the intended function, so you would want to do a bit of reading and research before attempting this.
| Rebel XSi | EF-s 18-55 f/3.5-5.6 IS | EF 50 f/1.4 | EF 70-200 f/4L | Speedlight 199A |
bohdank
Apr 05, 2009 10:12 |  #12
I imagine the quality of the images that would come out of that lens with TC would be pretty poor.
1,124 views & 0 likes for this thread, 8 members have posted to it.
adding more zoom
1031 guests, 113 members online
