Hey guys.
The market offers too many damn filters to chose from!! And I have completely gone filter crazy. Here's what I own...
Canon Rebel XTi
18-55mm (58mm) kit lens
28-135mm IS (72mm)
50mm 1.4 (58mm)
I need to plan around a trip I'm taking in 2 1.2 weeks near Yosemite. I plan on capturing some sweet shots of waterfalls, etc etc. The lighting may be harsh in places, and there likely will be snow.
FULL DESCRIPTION
It was described to me that a ND 2 stop and/or a CPL would be helpful. So I went shopping online today. Wow, I had no idea how tough this would be.
I have three questions...
1) I have cheapo Tiffen UV filters presently on my 28-135mm (72mm) and 50mm (58mm). Will I see a big enough difference in upgrading to B+W UV filters? In other words, would it be worth the UV B+W 100 dollar upgrade for both lenses?
2) What stop ND filters do you recommend for waterfall silky smooth captures? Will 0.6 (2 stops) be enough do you think? (how often do you use your 0.9 filters?) If you had to chose one over the other (ND vs CPL)... which would it be? Combo suggestions?
3) Does anyone have experience with 58mm to 72mm Step-Up Rings (filter adapters)? Does it distort the image at all? Any things I need to be aware of? I'm buying 72mm filters in mind that I can use this on my 58m. Is this a bad idea?
Here's what I picked out (not purchased yet), but I need to kill either the CPL or the ND filter. But if the UV filters aren't going to matter then I will gladly kill those from my list to get both ND and CPL.
See...
1. B+W 72mm MRC UV 010 Filter NEW F-PRO Multi-Coated Alloy
2. B+W 58mm MRC UV 010 Filter NEW F-PRO Multi-Coated Alloy
3. SLIM B+W 72mm Circular Polarizer C-POL Filter NEW
4. B+W 58mm to 72mm Step-Up Ring (Lens to Filter) #1E New
5. Hoya 72mm Neutral Density - ND - 4x Glass Filter NEW
Total: 170.34
I need to lose something from this list to bring it under 120.
I'm feeling overwhelmed here.
Please help.
