Thread started 11 Apr 2005 (Monday) 22:23
Tell me about external flashes
jon1996
Apr 11, 2005 22:23 |  #1
I have been reading about flashes that go on the hotshoe on top of a camera, they say it helps alot? Why is it better than the on board flash set on high? I have a G6 by the way
later,
jon
Canon 20D
18-55 IS, 55-250 IS, 50 1.8,
Panasonic FZ50
Canon G6 with about 40,000 Pics
www.jonsphoto.smugmug.​com (external link)
ryno4youth
Apr 11, 2005 22:59 |  #2
For me, the two most important advantages to using a external flash are Power and Angle. First, you get much more power and depth in the light vs the on board flash. Second, you can adjust the angle of the flash and either "bounce" the ligth off of a wall or something, or you can also use a diffuser that make the light look great. Sometimes when I use one, you cannot even tell that I was using a flash at all (then there are times when I just have to hit the delete key). Good Luck!
Keep Lookin' Up!
20D (w/ Grip), DRebel (w/ Grip), Sigma 70-200mm f2.8, Canon 17-85mm IS USM, Canon 17-40 f4L, Sigma 28-105mm, Kit Lens, Nifty Fifty, Canon 75-300mm, 4GB Sandisk Ultra CF, 2GB Sandisk CF, 1GB Extreme CF, Hakuba HG-504MX Carbon Fiber Tripod, Slik Pistol Grip Head, Carbon Fiber Monopod, Sigma EF Super DG External Flash, Kata Backpack, POTN Neck Strap, etc.
Company Website: http://www.lindbeckpho​to.com (external link)
Capturing Memories, a thousand words at a time...
rgravel
Joined Apr 2004
Apr 12, 2005 06:03 |  #3
External flashes are great in helping reduce / eliminate red eye.
1) You can bounce the light on a wall or ceiling as previously mentioned,
2) Since the flash is now further away from the lens compared to the internal flash, the light now hits the eyes at an angle instead of almost straight on, reducing the chances of having red eyes.
Bye
Robert Gravel www.robertgravel.ca/ (external link)
EOS 7D + grip, EF 400 f5.6 L, EF 70-200 f4 I.S. L, EF 17-40 f4 L, EF 24-105 L, EF 100 f2.8 macro, EF 40 Pancake, 430 EX II, 430 EX, S90, EOS Elan 7N
dwil49
Apr 14, 2005 20:38 as a reply to  @ rgravel's post |  #4
I have a Canon 420EX flash with a Sto-fen Omnibounce diffuser and it takes great pics. One other good reason for having the external flash is that lens adapters can get in the way of the builtin flash and you end up with a dark area in one corner of the pic. Not such a big deal if you can crop it out, but you don't get that with the external flash.
steve547
Apr 22, 2005 21:44 |  #5
You might want to try out the flash on the hotshoe of your camera before you buy it. Not all flashes will fire on my G2. I'm pretty sure a canon flash will work.
Steve
_____
EOS 20D, EOS 5D MARK III,18-55mm kit lens, Canon 35mm/f2, Canon EF 24-105 f/4L IS USM, Canon 220EX, Sigma EF-500 DG ST, G2, Canon i960 photoprinter, Canon Pixma Pro 9000 printer, Tamron 17-50 f2.8 non vc.
Ballen ­ Photo
Gallery: 13 photos
Joined Nov 2003
Apr 22, 2005 22:05 as a reply to  @ rgravel's post |  #6
Bye
These are all very good reasons, along with more power (Higher GN), more versatillity, more options, (Like diffusers and off camera flash via brackets like stroboframe in conjunction with the correct off shoe cable.) Adjustable power on some models, Tilt and bounce options, and especially eliminating Red eye.
-Bruce
The Captain and crew finally got their stuff together, now if we can only remember where we left it. :cool:
verT
Joined Jun 2003
Apr 26, 2005 12:07 |  #7
All the reasons that everyone has listed are the reasons I bought a 420EX for my G3.
350D w/BG-E3, Tamron SP AF17-50mm F/2.8 XR Di II LD Aspherical [IF], Canon EF-S 17-85mm f/4-5.6 IS USM, Sigma 70-200mm f/2.8 EX DG Macro APO HSM, Canon SpeedLite 420EX, SD450, dinky tripod that needs to be replaced.
2,229 views & 0 likes for this thread, 7 members have posted to it.
2535 guests, 96 members online
