Thread started 11 Apr 2005 (Monday) 22:25
DO you use the LCD or VF on your G6
jon1996
Apr 11, 2005 22:25 |  #1
I use mostly the LCD on my G6, Ao what about everyone else here?
later,
jon
Canon 20D
18-55 IS, 55-250 IS, 50 1.8,
Panasonic FZ50
Canon G6 with about 40,000 Pics
www.jonsphoto.smugmug.​com (external link)
Nabil-A
Joined Dec 2004
Apr 11, 2005 22:50 |  #2
I prefer to use the LCD, however where i have a number of similiar photos where where lighting doesnt change ( or things are pretty constant) then i use the VF to frame the shot being full aware of its cropping of the actual photo (as shown on the LCD).
http://www.photography​bynabil.com (external link)
http://www.designerpor​traits.com.au (external link)
http://www.lovestories​photography.com.au (external link)
gkuenning
Joined Jan 2005
Apr 12, 2005 07:58 |  #3
I much prefer the viewfinder on my G3 because I think it's a more natural position for holding the camera. However, I also use the LCD a lot to avoid parallax. The LCD is also nice for getting candids, since people often think you're reviewing your old photos instead of taking new ones.
I wish somebody would make a digicam with an eye-level LCD viewfinder, the way they do on camcorders. It seems like a great way to eliminate parallax without going to the cost (and mirror noise) of a proper SLR.
Geoff
All I want is a 10-2000 f/0.5L with no distortion that weighs 100 grams, fits in my pocket, and costs $300. Is that too much to ask?
kring
Apr 12, 2005 08:25 as a reply to  @ gkuenning's post |  #4
Doesn't the Canon Pro1 have an electronic LCD viewfinder? or are you refering to a viewfinder accessible from the top of the camera?
Canon 30D
Canon Rebel XT Silver
Canon EF 50mm f/1.4 USM
Canon EF-S 17-85mm IS USM (Hoya Pro1 UV & Lens Hood)
Canon 430EX Flash (Sto Fen Omni-Bounce)
magicmikey
Apr 12, 2005 08:50 |  #5
Indeed, the Canon Pro 1 has an EVF (electronic viewfinder.) I use the LCD on my G6 99% of the time. I like the optical viewfinder when I'm trying to photograph my kids doing sporting events because I think it's easier but since I added the TC-DC58n (teleconverter), that's out because the optical viewfinder doesn't know that the lens has been multiplied 1.75X.
S45_fornow...
Joined Dec 2003
Apr 12, 2005 08:58 as a reply to  @ magicmikey's post |  #6
LCD 85-90% of time. I use the VF for extra stability when taking handheld shots at slow shutter speeds.
O-G
Apr 12, 2005 09:27 as a reply to  @ S45_fornow...'s post |  #7
LCD 100 % when I can. Unfortunately, outdoors I can only use the LCD about 10%. Unless I can get out of the sun the LCD on my G6 is unviewable.
BottomBracket
Joined Dec 2004
Apr 12, 2005 09:47 as a reply to  @ O-G's post |  #8
It depends on the situation. I would say I use the LCD most of the time, especially when there are filters or wide or tele attachements on. You have to look at the LCD to see the full effect of a polarizer, for example. There are times when you need the viewfinder though, like when taking pictures in bright sunlight, which totally washes over the LCD image. Sometimes I use the viewfinder when i low light too, when I need to brace the camera against my face to prevent camera shake.
Sometimes I don't use either one. When I do candid or street photography, I just aim the camera in the general direction of my subject and shoot away. Of course having the camera stopped down for great DOF and with the lens at the widest focal length helps a lot. Putting the camera in hyperfocal setting does the trick too. There are times, like when on the subway, I put my G6 inside my jacket's sleeve with the lens peering out. This way I can take inconspicuous pictures with no one being the wiser.
Pio
Veni, Vidi, Canoni - I Came, I Saw, I Took A Picture With My Canon
Fotopio.com - Gallery of the Meandering Eye (external link)
I am a leaf on the wind. Watch how I soar.
Feihung08
Apr 12, 2005 10:34 as a reply to  @ BottomBracket's post |  #9
Does the protruding lens block part of the VF on the G6 like it does on the G5??
Canon 80D | Tamron 28-75mm | Canon 50mm 1.8 | Canon 430 EX | LensBaby 2.0
magicmikey
Apr 12, 2005 10:45 |  #10
Feihung08,
If you're referring to the teleconverter or wide angle converter, yes it does block part of the optical viewfinder.
kring
Apr 12, 2005 10:59 as a reply to  @ Feihung08's post |  #11
I think your refering to the standard lens. No it does not block it like the G5, the changes to the body of the G6 moved the lens to the bottom left of the camera and it no longer blocks that small portion of the VF.
Canon 30D
magicmikey
Apr 12, 2005 12:17 as a reply to  @ kring's post |  #12
I see. I've never used a G5, only the G6.
Nabil-A
Joined Dec 2004
Apr 12, 2005 15:56 as a reply to  @ gkuenning's post |  #13
It already has been done, its called EVF Electronic View Finder. Just that canon hasnt incorporated it into any of its P &S
Feihung08
Apr 12, 2005 17:20 as a reply to  @ kring's post |  #14
Yup! Thats what I was talking about. THANKS!
That's a big reason why I don't use the G5 VF, that and none of the settings info are viewable in the VF like on an SLR. Which is why I got to have a 20D!
BottomBracket
Joined Dec 2004
Apr 15, 2005 06:46 as a reply to  @ Nabil-A's post |  #15
Actually the Pro1 is an EVF camera.
Pio
4,221 views & 0 likes for this thread, 22 members have posted to it.
2297 guests, 93 members online
