Thread started 12 Apr 2005 (Tuesday) 01:08
Macro photography focusing & lenses
algae
Apr 12, 2005 01:08 |  #1
I am using a Canon G5 with the ring flash to take macro photos of coins. The manual is confusing me as to what settings I should be using. On the page entitled Macro Mode it says to press the "flower button" to enter Macro Mode, but it does not say anything about what to set the mode dial at (Auto, P, Av, M ?) I am trying to get very crisp photos of the surface of the coin, or a particular area of a coin or the edge reeding, so focus is critical for detail. Invariably when I begin to take a picture the focus goes in and out and invariably ends up out of focus. Then when I push the manual focus button, the camera goes out of macro mode and I have great difficulty getting the image as seen through the viewer in crisp focus. I have diopters of 1, 2, 4, & 10 which I have tried at various zooms, but the focusing is still the issue. Am I doing something wrong? The manual also mentions the 250D close-up lens which "makes macro shooting easier". From other threads it would seem that this lens is merely a +4 diopter. Is that true or does it somehow allow easier focusing and why is the range in macro mode as close as 2 inches but with the 250D it becomes almost 4 inches? It doesn't seem to make sense that in putting on a close-up lens you have to get farther from the object.
gkuenning
Joined Jan 2005
Apr 12, 2005 07:55 |  #2
The camera goes out of macro ("flower") mode when you choose manual focus because in MF mode, you have the full range from macro to infinity all on one dial.
Here's one suggestion that I haven't tried: cover your subject with a white card that has a few (1-3) strong black lines in the focusing area. Orient the card with the black lines "vertical" to the LCD image. In any mode except Auto, press the shutter button halfway and hold it, then press the MF button and release the shutter. Pressing halfway should cause the camera to focus on the thin card. Pressing MF locks the focus. Now you can remove the card and take your shot.
This is also a good place for focus bracketing. You may also want to go into Av and pick f/8 to get a bit more depth of field.
Geoff
All I want is a 10-2000 f/0.5L with no distortion that weighs 100 grams, fits in my pocket, and costs $300. Is that too much to ask?
algae
Apr 12, 2005 20:03 as a reply to  @ gkuenning's post |  #3
I will try this. I can see that this would give you a very distinct object to focus on. I was rather hoping to be able to just pop a coin under my set up and snap away, one after the other, but that might be a little beyond the state of the art this time. At least I won't be chewing up film by bracketing focus. Thanks for the good tips.
Lou
Flagpole
Joined Mar 2003
Apr 13, 2005 06:21 |  #4
G'day!
Check this page out http://www.lensmateonl​ine.com/G3G5macrocomp.​html (external link)
Flagpole
G2, 420EX, Tiffen 0.75x & 2.0x, Lumiquest Pro Max
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Apr 13, 2005 07:29 |  #5
Have you tried using indirect lighting? It would also give you a higher light level for focusing.
https://photography-on-the.net/forum/showthre​ad.php?t=67249
1,815 views & 0 likes for this thread, 4 members have posted to it.
2284 guests, 93 members online
