Thread started 06 Apr 2009 (Monday) 21:49
My first posting in this forum
FreezeTheMoment
Apr 06, 2009 21:49 |  #1
Hello, here are some baby pictures that I took. Please feel free to comment. I'm new to DSLR, looking for room of improvement.
These pictures are taken either by Canon 85mm f/1.8 or Tamron 17-50mm f/2.8 on an XSi. Usually I set the aperture as big as possible. If flash is used, it's Speedlite 430EX with a diffuser and pointing at the ceiling. By the way, except a few setting in converting from RAW to JPG, and sometimes removing red eyes, with CS4, I pretty much have not done any processing.
Gear list
A hobbyist here. I like taking pictures of people.
FreezeTheMoment
Apr 06, 2009 21:50 |  #2
#3 and #4
Gear list
FreezeTheMoment
Apr 06, 2009 21:50 as a reply to  @ FreezeTheMoment's post |  #3
#5 and #6
Gear list
FreezeTheMoment
Apr 06, 2009 21:51 as a reply to  @ FreezeTheMoment's post |  #4
#7 and #8
Gear list
Guineh
Apr 07, 2009 07:11 |  #5
Sure is a cute little guy... :) I especially like #6.
Some advice:
If you have a low enough and white enough ceiling, try using the flash without the diffuser, I noticed the shadows in the first picture. What you'll lose without the diffuser is the catchlights in the eyes. You may want to vary the aperture a bit to increase the depth of field, so more of the baby's head is in focus (Exif shows a f1.8 aperture, and an 85mm focal length, that's a pretty thin DOF) , but then that depends on what style you're going for.
I'd say you're getting the hang of it!
FreezeTheMoment
Apr 07, 2009 12:29 |  #6
Diffuser can give catchlights in the eyes... right... I haven't thought about that! Thank you, Guineh, for this and other advices! Yes, the ceiling there is pretty low and white enough. I'll try to flash without a diffuser.
Gear list
JoShAdKa4
Apr 07, 2009 20:21 |  #7
Hi, Welcome and, I'm new here myself so not much help on the technique. I really like 6 & 7, too cute.... thank you for sharing.
Cindy
shaftmaster
Apr 07, 2009 22:06 |  #8
Try shooting at ISO400 to allow a faster shutter speed. The shutter speed for hand-held shots should be faster than 1/(focal length*crop factor), so for 85mm lens you need probably 1/150 second or faster (1/200, etc.).
I'd also stop-down the aperture to increase the depth of field. At f/1.8 your DOF is pretty small.
Paul
Gear -- Flickr (external link)
FreezeTheMoment
Apr 08, 2009 00:57 |  #9
JoShAdKa4 wrote in post #7687997 (external link)
Hi, Cindy, thanks for your reply! I hope soon there are some pictures from you. :)
Gear list
FreezeTheMoment
Apr 08, 2009 01:01 |  #10
shaftmaster wrote in post #7688604 (external link)
I'm not sure about ISO 400. That seems too much. It could compromise the image quality, unless it's grayscale. By the way, I usually think that 1/40 or 1/50 is enough to get a clear image from a moving baby. Is 1/150 too much?
Gear list
Guineh
Apr 08, 2009 08:03 |  #11
colormaniac wrote in post #7689467 (external link)
Really with these cameras ISO400 is reasonably safe. 1/40 is a rather slow shutter speed, especially for a fast moving kid. You can probably get away with ISO800, too.
shaftmaster
Apr 08, 2009 22:30 |  #12
I'll bet you will have a hard time seeing a difference between ISO100 and ISO400 unless you make huge prints or spend your time looking at 100% crops. Regardless, high ISO noise can be corrected in post-processing but blurry images due to subject movement or camera shake cannot be corrected. ISO400 is your friend. I'd much rather have a usable shot taken at ISO400 than an unusable shot taken at ISO100. Many pro camera bodies support ISO 3200, 6400, and higher for a good reason -- sometimes you need it to get a usable shot.
Paul
FreezeTheMoment
Apr 09, 2009 02:02 |  #13
shaftmaster wrote in post #7695215 (external link)
I'll take your advice and try it. However, I do notice the difference between ISO100 and ISO400 on my 23'' HDTV monitor. Actually it looks like brightened up pictures with ISO100 by PhotoShop. There will be quite a lot of noise. Since I hope some pictures can be printed and framed, I hope to use lower ISO just in case that's one of my best shots.
Gear list
2,020 views & 0 likes for this thread, 4 members have posted to it.
1184 guests, 108 members online
