Thread started 12 Apr 2005 (Tuesday) 13:13
G6 minimum focusing distance at max zoom
GenEOS
Joined Jan 2003
Apr 12, 2005 13:13 |  #1
Is anyone noticing any focusing problems with the G6 at maximum zoom and being closer to your subect (4 feet ot there about)? I have noticed that when set to the widest setting it is tack sharp and locks focus pretty easy, even in lower light. But, if I step back from my subject and zoom in, the lens hunts for focus, sometimes locking at an un-focused point and allowing a blurred shot.
What is the minimum focusing distance of the lens at maximum zoom?
Daniel Tunstall
http://www.dmtphoto.co​m (external link)
Sports Shooter Member
http://www.sportsshoot​er.com/members.html?id​=2474 (external link)
dkord
Apr 12, 2005 22:59 |  #2
Played around with one today, I got it under 2 feet (I think the manual says 1.6 feet) with no problems. Closer in, I used the macro.
This is fully zoomed
If you're having trouble, try shooting in P and going into the menu and turning off AIAF.
The devil is in the details...Especially at 100% crop!
https://www.flickr.com​/photos/eosdawg/ (external link)
S45_fornow...
Joined Dec 2003
Apr 13, 2005 06:22 as a reply to  @ dkord's post |  #3
Yes, the specs list the focus distance for Normal AF at 20 inches (1.67 ft) to infinity.
I checked mine last nite and it worked fine. I use center-focus only.
It depends on the lighting and amount of vertical contrast available also. In low light, full-zoom may be problematic with getting a sharp focus lock.
I'd check it in broad daylight as a real test to see if the focus distance is functioning properly.
2,095 views & 0 likes for this thread, 3 members have posted to it.
1682 guests, 137 members online
