Thread started 08 Apr 2009 (Wednesday) 17:52
Sync speed below spec? Canon 1DsMarkII
sfaust
Apr 08, 2009 17:52 |  #1
Anyone else notice this?
I was testing my new light meter and calibrating it to the 1DsMarkII. I was shooting a MacBeth chart, and to test the shutter sync speed I decided to put a gray seamless behind it in order to better show the shutter
When I did the high speed sync test, I found that at the 1/250th stated sync speed, I get a vertical band along the bottom of the frame I from the shutter. It isn't real pronounced, Capture One only shows it drops off about 10% or so, but it is there and can be easily seen. When I change to 1/180th, its gone.
Would the shutter drift like this? Drifting slower such that it will effect the sync speed. It seems very reasonable, but then again I don't know how the shutter mechanism is engineered to know for sure.
Just wondering if its time to send in the camera for a cleaning, checkup. Or if its entirely normal, even though its just under what the specs show.
Stephen
Commercial Photography (external link)
cicopo
Gallery: 242 photos
Apr 08, 2009 18:19 |  #2
Were you using a Speedlight or studio flash? The manual lists 1/125 sec for non speedlight type strobes.
A skill is developed through constant practice with a passion to improve, not bought.
sandpiper
Apr 08, 2009 18:33 as a reply to  @ cicopo's post |  #3
Also, how were you firing the flash? If using a radio or optical trigger, that can cause a slight delay in firing that means the shutter has just started to close when they fire, at max synch speed.
I know I habitually shoot a little slower than the official synch speed with my 5D, as I can get a black edge sometimes if I use the max synch speed. I can get max synch with the speedlite in the hotshoe, but not studio strobes.
RDKirk
Adorama says I'm "packed."
Joined May 2004
Apr 08, 2009 18:38 as a reply to  @ sandpiper's post |  #4
Be sure you're syncing with a wire, not a radio. The 1-Series camera specification actually has a fairly healthy safety factor--the actual sync is about 1/320.
The worse case is that you're suffering from shutter bounce, which will show itself in that way. It's a symptom of a failing shutter. Google for Canon shutter bounce for more information.
sfaust
Apr 08, 2009 22:41 |  #5
Bingo, never even occurred to me about the delay from radio sync or using studio strobes. You're right, I should have dove deeper into the manual since there it is! I was using studio strobes, and pocket wizards.
I also generally shoot slower, typically at 1/160th, just because I like to have that extra margin. But yea, totally spaced on the delay factor.
Thanks.
Stephen
bauerman
discount on value meals
Joined Apr 2003
Apr 09, 2009 07:43 |  #6
You guys with your 1/250th sync speeds - I much prefer my 1/500th!!
sfaust
Apr 09, 2009 08:31 |  #7
And I much prefer my Rolleiflex at 1/1000 ;)
Stephen
bauerman
Joined Apr 2003
Apr 09, 2009 08:32 |  #8
sfaust wrote in post #7697106 (external link)
Showoff....
René ­ Damkot
Apr 09, 2009 20:17 |  #9
bauerman wrote in post #7697110 (external link)
Showoff....
I like the 1/2500s of my 1Dino ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
sfaust
Apr 09, 2009 20:30 |  #10
What is a 1Dino??
Stephen
bauerman
Joined Apr 2003
Apr 09, 2009 21:56 |  #11
1D sync speed is 1/500 as far as I know.....
René ­ Damkot
Apr 11, 2009 13:44 |  #12
1 Dino = 1D Mk1 = 1D "classic" = 1D.
Sync speed with a canon ETTL flash attached (say a 550EX) is 1/500s. But as long as the camera doesn't know there's a flash, it'll happily sync at all speeds. (tested it with a 580EX with all contacts except the center taped, and got reliable flash exposure up to 1/2500s).
This is because the shutter is never faster than about 1/250s (exposing the whole sensor), and all faster shutterspeeds are created by switching the CCD on and off.
sfaust
Apr 11, 2009 16:03 |  #13
Gotcha! I had one of those beasts at one time.
I remember hearing about that trick. Only works with the hot shoe flashes, yes? (Ie, not with my studio strobes)
Stephen
René ­ Damkot
Apr 12, 2009 10:36 |  #14
I think that depends on the speed and flash duration of the studio flash... Would be interesting to see what a 1D could do with the new Pocketwizzards. (Since they get a 1DMk3 to sync at 1/500s) ;)
I'd guess you could sync up to 1/16000s then :shock:
sfaust
Apr 12, 2009 12:48 |  #15
The next person that shows up a my workshop with a 1D will get some extra attention from me, so we can test it out.
Stephen
2,197 views & 0 likes for this thread
Latest registered member is aamsergie
1188 guests, 248 members online
