Thread started 09 Apr 2009 (Thursday) 00:20
EOS 5D Mark II Noise Reduction in RAW
fzihlmann
Apr 09, 2009 00:20 |  #1
I got my new EOS 5D Mark II and shoot in RAW. I would like to know if the C.Fn II-1 and C.Fn II-2 (Long exposure and high ISO speed) noise reduction function settings apply to RAW.
Panopeeper
Apr 09, 2009 09:34 |  #2
Long exposure yes; but test if you like that, for it is somewhat brute, it can cause "black holes" at hot pixels.
High ISO: not. However, if you process the image in DPP, the setting will be automatically applied, though you can change it.
Gabor
fzihlmann
Apr 09, 2009 16:05 as a reply to  @ Panopeeper's post |  #3
Thank you Gabor for the crisp answer.
I use Adobe Lightroom 2.3 and wonder if I can achieve High ISO Speed noise reduction similar to DPP?
Panopeeper
Apr 09, 2009 17:51 |  #4
fzihlmann wrote in post #7699778 (external link)
I would not venture to judge which one is better, but I would not be surprized if DPP turned out to be the better one. However, there is no need to perform the complete noise reduction at that level. If the image is noisy, then *some* NR should be done in the raw conversion phase. This is unavoidable with ACR; even if you request zero NR, ACR will do some NR.
On the other hand, I see a problem in your question: "high ISO noise reduction". High ISO is not responsible for the noise. I suggest you to read http://www.cryptobola.​com/PhotoBola/SourceOf​Noise.htm (external link)
Warning: this is a very detailed, pixel peeping treatment of the subject; some readers found it ununderstandably detailed.
If we are at it: 5D2 and ISO. Following is strictly for 5D2 raw shooters:
1. ISO 160, 320, 640 and 1250 are identical to 200, 400, 800 and 1600, respectively, regarding noise. However, these can cause overexposure compared to the full-stop ISO, because the ISO gain is identical, but the exposure (if metered) is 1/3 stop higher with the full stop -1/3 EV ISO steps. So, if used at all, then with -1/3 EV bias - but then you are at the next higher ISO, so why using this one?
2. ISO 125, 250 and 500 are worse than the next higher full stop ISO. This is because they are created by multiplying ISO 100, 200 and 400, respectively, by 1.26; the noise too gets multiplied by 1.26, but when going a full stop higher, the noise increases less than by a factor of 1.26.
3. ISO 1000 is a special case: its noise is 1.29 higher than that of ISO 800, but the noise of ISO 1600 is 1.41 times higher than that of ISO 800 (the analog gain loses the "teeth" at this level).
4. ISO 125, 250, 500 and 1000 cause a reduction of the DR by 1/3 stop.
5. All ISO steps over 1600 are useless regarding noise. They simply reduce the DR by 1/3 EV respectively 1 EV. The only reason to use those is to have brighter preview.
Gabor
basroil
Apr 09, 2009 17:56 |  #5
Panopeeper wrote in post #7697445 (external link)
Dunno about the second there, mkiii shows a mild difference between it being on and off. On removes chroma, leaves minor watermark effect at 6400, just removes a bit of chroma at 3200. If LR needed NR of 15 with in camera NR off, same shot is generally an 11-12. Nothing major, but i can see a difference there. Either LR detects the flag or the raw is changed.
Panopeeper
Apr 09, 2009 18:02 |  #6
basroil wrote in post #7700264 (external link)
This is interesting, for LR (which shares the raw processing with ACR) does not honor in-camera settings except WB and HTP (the latter only halfway).
Do you happen to have such a pair of shots (raw files) demonstrating this? I can verify if the raw is affected, though that would be a "first" of Canon.
Gabor
fzihlmann
Apr 10, 2009 00:19 as a reply to  @ Panopeeper's post |  #7
Thanks again for great actionable response. The reason for my noise reduction question is because I will be photographing in the Upper Antelope Valley next week. It’s my first visit to this location and I understand that the slot canyons are fairly dark. My objective will be to balance between HIGH ISO speed and Long Exposure times.
Panopeeper
Apr 10, 2009 00:55 |  #8
fzihlmann wrote in post #7702197 (external link)
Well, this is a whole new twist and it has nothing to do with the topic you started. I suggest you to read the discussion http://luminous-landscape.com …owtopic=33049&h​l=antelope (external link)
YOU WILL NOT MAKE ANY LONG EXPOSURE THERE.
Gabor
6,808 views & 0 likes for this thread
Latest registered member is Sonechka
862 guests, 297 members online
